New powersteering gear box ?
Old May 9, 2007 | 09:57 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I want to take out the powersteering and put in a quick ratio gear box. What would work with a 84 Z28 ?
Old May 13, 2007 | 12:46 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Re: New powersteering gear box ?
Maybe you can get lucky like I did. Go to the local U-pull yard and find some 3rd gen. firebird or cam-air-O and turn the steering wheel lock to lock (left to right) 2 1/2 times. That is a (what GM calls sport steering) and you have found a quick steering ratio box. Here in Indiana, it's 10 to 15 bucks for U-pull-it.
Old May 13, 2007 | 10:02 AM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
get in touch with capt chip. he will convert your box for about 200.00
Old Jul 21, 2007 | 06:52 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
who the h*ll is capt chip?
Old Jul 21, 2007 | 07:12 PM
jjlabinski's Avatar
Engine: shinny 350
Wow I see the email is back working on this site. Answering e-mails sent months ago. I will get you the cap'ns number he does great work. About 25 bucks each way frieght but he will make your stock box anyway you want it. He even put custom stops in mine for the massively wide front tires I have.
jeff
Old Jul 21, 2007 | 07:32 PM
sounds good thanks
Old Jul 21, 2007 | 07:49 PM
jjlabinski's Avatar
Engine: shinny 350
capn chip...www.powersteering.com
Old Jul 22, 2007 | 12:06 PM
awesome good lookin out
Old Nov 28, 2007 | 01:41 AM
kscamaro89's Avatar
Car: 2002 MINI Cooper S
Engine: 1.6L Inline 4 Supercharged
Transmission: 6 SPD
OK so 12:1 is considered Quick ratio steering. I believe I have one, but want quicker. I'm setting my 89 up for drifting. So do I want 10:1 or 14:1? Which way do I go?
Old Nov 28, 2007 | 08:33 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Does the ratio of steering affect the stiffness of thw steering wheel? Because my buddies base model 87 firebird has the steering wheel real easy to turn, stopped or moving. My car, though, I think might have the quick ratio steering. The steering in my car is more responsive, but the wheel is pretty firm to turn.
My last car, FWD monte carlo, was alot easier than the firebird. But my buddies oldsmobile Aurora was the easiest to turn I have ever felt!
I wish I could have the quick ratio steering I guess I have now, but have the wheel only need a finger to turn like the aurora!
Old Nov 28, 2007 | 10:42 PM
kscamaro89's Avatar
Transmission: 6 SPD
turn your steering wheel all the way to the left. then turn all the way to the right.if it's a quick ratio it should be 2 1/2 turns to go left to right.
I also found out that 12:1 is as quick as you can get/rebuild to. Higher the number slow it is also.
Mine is hard to turn as well unless moving. it doesn't feel like its a PS problem though. FWD cars I think usually have slower turning cause when traction breaks they jump to the right and are geared so they're easy to correct. Something like that anyways.
junkcltr
Aug 2, 2019 11:12 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
hectre13
Aug 26, 2015 08:17 AM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
