Valve cover torque specs?
Old Jul 5, 2007 | 10:09 PM
ztweny8's Avatar
Car: 82 Z28
Engine: SBC 350
Transmission: 700R4 w/Shift kit
Just bought some Holley Cast Aluminum valve covers for my carb'd 350. Just wondering how tight I should bolt em down. I have the wingnut style valve cover bolts btw.
Old Jul 5, 2007 | 10:26 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: Valve cover torque specs?
They dont need much. "Snug" or no more than 16 ft/lbs i beleive.
Old Jul 5, 2007 | 10:30 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
just untill they feel tight then after a week make sure there all still tight, With alloy covers its not realy a problem because they don't bow like the tin ones.
EDIT: oh damn he beat me to it.
Old Jul 5, 2007 | 11:14 PM
ztweny8's Avatar
Car: 82 Z28
Engine: SBC 350
thanks
Old Jul 6, 2007 | 05:35 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
what kinda gaskets are you using? Some people swear by cork or rubber. I use teflon gaskets, little pricy, but are rigid and don't loose form when handling them. Just silicone gasket to the cover and let the gasket do its job on the head.
Old Jul 7, 2007 | 06:47 PM
ztweny8's Avatar
Car: 82 Z28
Engine: SBC 350
yeah, their cork. And thats the same thing I did, RTV sealer to cover, and then put on head.
Old Jul 9, 2007 | 12:04 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you use cork, 'glue' them to the valve cover with silicone, and then just let them but up against the head w/o any sealant. That way they can be reused when you take the valve cover off again. I did this with my tin set and my aluminum set.
Old Jul 9, 2007 | 12:15 AM
ztweny8's Avatar
Car: 82 Z28
Engine: SBC 350
yeah, thats what im doing.
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
