Mounting to a stand ... which bolts?
Old Sep 1, 2007 | 03:55 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
I'm getting ready to mount an L98 to my engine stand. What size/thread bolts should I use?
Old Sep 1, 2007 | 05:08 PM
gcgarner's Avatar
Re: Mounting to a stand ... which bolts?
OK, found out through Google that I need 3/8" 16 thread bolts. Now I need to know how deep the bolt holes are in the block so I can get the correct length. Anybody got an answer?
Old Sep 1, 2007 | 05:48 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
3.5" and some washers from home depot works fine on my stand, yours could be different
Old Sep 1, 2007 | 06:29 PM
Aim for about ¾" of threads past the stand and into the hole.
Old Sep 1, 2007 | 07:06 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
The first time I had a complete 440 break off an engine stand I started using grade 8 bolts to hold the engines on instead of anything that would fit.
Old Sep 1, 2007 | 08:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
make damn sure you use grade 8 bolts nothing less
Old Sep 1, 2007 | 08:34 PM
gcgarner's Avatar
I measured into the threads on the block. They're 1" deep. The extensions on my stand are 2.5, so I went to Lowe's and got 3.5" bolts and some washers.
They only had 3 Grade 8's in the bin, so I got all three and one Grade 5 ... should this be OK, or should I wait until Wednesday when they get more Grade 8's in?
Old Sep 1, 2007 | 08:43 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I used 3" bolts because the 3.5" bolts were far too long.
Old Sep 1, 2007 | 08:53 PM
Should be just fine.
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Elliswon
Aug 10, 2015 12:33 PM
