Removing papint from Intake manifold?
Old Nov 13, 2007 | 08:57 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Hey guys, whey I assmebled my heads/intake combo, I painted the intake black to make a sleeper look to the engine bay. Now after some gas leaks and what not, it looks like a zebra. What can I use to remove the paint completely. I will be taking the manifold off to do this. Brake clean?
Old Nov 13, 2007 | 09:02 AM
Re: Removing papint from Intake manifold?
Permatex 4MA gasket remover or Easy-Off oven cleaner, followed by the thin kind of paint stripper that has acetone or MEK or toluene in it; at the quarter car wash.
Sometimes, putting it in the dishwasher can have an amazing effect.
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
Sandblasting looks great if you can do it.
Old Nov 13, 2007 | 09:05 AM
Car: 91 Firebird
Engine: Turbo 355
I don't have access to a sandblaster. Dishwasher? I would have never thought that would work?
Old Nov 13, 2007 | 10:14 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Any machine shop can sandblast for you for a fair price.
Old Nov 13, 2007 | 01:04 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I thought dishwashing detergent is supposed to be hard on aluminum..?
I'd just bring it to the quarter car wash. Set it on the ground and soak it in Easy-off. Go get a burger. Then come back and hose it off. It should sparkle it'll be so clean. Or a spray can of paint stripper, and let it soak.
Old Nov 13, 2007 | 06:12 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I don't think sandblasting is what you want... you want it BEAD blasted, if you are going to get it blasted at all. Sandblasting will clean it, but it will look really dull and rough.
Get it shot with glass bead (bead blasted) and it will look exactly like it does when a brand new intake manifold comes out of the box. I've done 3 intakes of my own this way, and countless customer parts this way - I used to have a job sand/bead blasting. On aluminum, glass bead is the only way to go
Old Nov 13, 2007 | 08:18 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
KUTZIT
This is some nasty sh**. But it will even take off factory paint (the stubborn kind).
Read & follow label directions carefully.
It's available almost everywhere that sells home improvement stuff.
Old Nov 14, 2007 | 03:02 PM
Car: 91 Firebird
Engine: Turbo 355
Thanks for the replies guys. I think I might give the KUTZIT a try. I'll let you guys know how it turns out.
Old Nov 14, 2007 | 07:58 PM
Engine: 350 4BBL
Be sure to give it enough time to work.
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
