heavy gasoline smell
Old Dec 3, 2007 | 02:25 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i have my new camaro parked in the garage and it has made the whole house smell like gas, so i aired the house out as well as the garage. i havent started it since yesterday, and it still smells like gas. i dont see any leaks, or anything. there is no fuel in the carb and yet the after taking the intake off the carb smells like really strong gasoline. this might be normal, but i dont really know. thanks in advance for any assistance.
Old Dec 3, 2007 | 03:52 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: heavy gasoline smell
impaled,
Once my car did the same thing but not to that scope. I would be driving and could smell gas from inside the car. For me the issue was a worn out gas cap. I think the plastic just warped over time. This is typical with the plastic ones so check it out you never know.
With mine the symptoms where:
- When turning the cap, it gets hard early on to tighten it down and starts to click only after a full turn or so.
- Over time it gets slowly tougher to turn.
- You can't remember the last time you've changed it!!
Post your findings,
Rabi C.
Old Dec 3, 2007 | 08:47 PM
impaled's Avatar
thanks for the idea. unfortunately the gas cap is a new locking cap and it fits tight and i cannot smell gas from the cap area when the cap is closed.
any other ideas?
Old Dec 3, 2007 | 08:52 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
When I saw this post earlier today about a strong gas smell and the first response was from onfire........I took this as a bad sign
Old Dec 3, 2007 | 09:08 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Old Dec 3, 2007 | 09:09 PM
BG84FBIRD's Avatar
Car: 84 Pontiac Firebird
Hey man!!
just
just had a thought maybe not the gas cap but have u tried the filler neck tube (a.k.a. the rubbar hose?). srry bout the double comment hit the wrong button
Old Dec 4, 2007 | 01:44 AM
onfire's Avatar
Car: 88 Formula 350
flrtin1,
What are you sayin !! You could always say hi man dont be shy
impaled,
Check your fuel lines going to your carb especially at the fuel filter.
Rabi C.
Old Dec 4, 2007 | 05:52 AM
flrtin1's Avatar
Engine: S/B
Originally Posted by onfire
flrtin1,
impaled,
Rabi C.
Lol nothing personal....just your screen name with a post about gas fumes
Old Dec 4, 2007 | 11:55 AM
impaled's Avatar
i have checked the filler tube that leads to the gas cap and it seems to be tight and i cannot smell gas anywhere near the gas cap/tank.
i will check on the fuel lines when i have some more time.
any other ideas are always welcome.
Old Dec 4, 2007 | 12:10 PM
Freakazooid52's Avatar
Car: 1986 firebird
Transmission: THM350
my car did that to, it always smelt like gas no matter what, brand new pump,lines, new carb, new everything.
I always wondered why I could only have 3/4 tank of gas, the first 1/4 i would go through in a hour, the rest took all week.
So while i was under it one day there was a small hole on the side of my tank letting gas out.
not saying its that, but the weirdest stuff can happen.
Old Dec 4, 2007 | 01:08 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
sounds like the charcoal canister has gone bad or needs cleaning.raise hood ,bet the gas smell is coming from under there .make sure its plugged in,do a search,later jimmy
Old Dec 5, 2007 | 01:25 PM
onfire's Avatar
Car: 88 Formula 350
impaled,
Did you figure it out? Do post what you found I'm curious to see what happened.
Firtin1,
Haha yea fire and gas fumes don't mix!!!
Rabi C.
Old Dec 5, 2007 | 08:00 PM
impaled's Avatar
i know where it is coming from but not exactly where it is coming from.
i noticed a little bit of fuel accumulation on the front bottom part of my intake manifold. so it must be leaking from the carb or something, but this leak must be really small, but just enough to smell.
i will check connections and gaskets on the carb and hopefully fix it.
if anyone knows where a carb would commonly leak from, please dont hesitate to let me know.
i will do it when i have time, and this is exam week, so i dont have much time.
Old Dec 21, 2007 | 12:29 PM
impaled's Avatar
for future searchers, i think i have solved the problem. it was coming from the carb and i have since turned the fuel pressure down with a fuel pressure regulator and it doesnt leak any more.
Old Dec 29, 2010 | 06:21 PM
radicule's Avatar
Car: 1991 Z28
Engine: Rebuilt .30 over 5.7 TPI
Transmission: TR400
Axle/Gears: 3:23
Did the new gas cap fix the problem foe you?
Old Dec 29, 2010 | 07:13 PM
torque_is_good's Avatar
he's probably not checking a 3 year old thread any more
anyway, he posted that a FPR resolved the issue
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
1992Z28!
Nov 19, 2015 07:33 AM
Dwayne614
Sep 29, 2015 11:05 PM
Glowsock
Sep 11, 2015 11:09 PM
