Intense shaking when driving
Old Dec 28, 2010 | 04:11 PM
jmilano89's Avatar
I have a 1992 Camaro rs 6 cylinder 5 spd and when i am driving and shifting gears it starts to shake very intensly, mostly when in 5th gear. even when i throw it into neutral to try and stop the shaking, it continues. Im thinking maybe a stuck lifter or something of that sort. Any ideas??
Old Dec 28, 2010 | 05:11 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: Intense shaking when driving
When exactly does the problem happen? All the time, or just when you're driving? At all speeds or only above a certain speed? It could be almost anything and impossible to diagnose without more information.
Old Dec 28, 2010 | 05:21 PM
jmilano89's Avatar
it happens at speeds around 40, and yes only when i am driving. when its at in idle, then no it never happens. i just find it weird that when i drop it into neutral, it continues shaking and will not go away for about 10 seconds, today it would stop for a while
Old Dec 29, 2010 | 04:03 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
It could be a bent axle. I had this problem, and I changed out the rear end. No more shaking.
Old Dec 29, 2010 | 04:41 PM
jmilano89's Avatar
but it JUST started doing it. and yes its speeds of 40+. if im in 5th gear and i keep the RPMS in between 1500 and 1700, it doesnt do it but as soon as i hit 1700 rpms, it does it
Old Dec 29, 2010 | 04:51 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
Alot of vibration/shaking problems come from a tire going bad.sometimes not so easy to visually see.
Old Dec 29, 2010 | 05:06 PM
howy3 is right. It could be a bad tire. At lower speeds, the problem might not show its self, but if the belts are separating, they may be giving way as the tire spins faster. I would try a spare to see if that doesn't do it.
Old Dec 29, 2010 | 05:07 PM
jmilano89's Avatar
that would make since only because when i turn sharply regardless of what way, it almost feels like i have a flat and sounds like rubbing or something. the car almost bounces a little bit
Old Dec 29, 2010 | 05:09 PM
jmilano89's Avatar
how do i know which tire is bad?
Old Dec 29, 2010 | 05:13 PM
The only way is process of elimination. I am assuming the shaking is coming from the rear?
Old Dec 29, 2010 | 05:20 PM
jmilano89's Avatar
i cannot tell. the whole car just shakes intensly. it almost feels like its coming from the front
Old Dec 29, 2010 | 05:23 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
if u feel the vibration in the steering wheel its in the front if you feel it in ur butt its in the back
Old Dec 29, 2010 | 05:25 PM
jmilano89's Avatar
steering wheel definatly. and the shifter shakes just as much as the steering wheel. it must be coming from one of the front tires then
Old Dec 29, 2010 | 06:35 PM
torque_is_good's Avatar
others have you going down a simple path to check. However, I'd like to offer a little clarification so you don't find yourself getting caught in what programmers call, "a loop"
you posted about rpm's
well, that is engine speed so if your engine was going to do something at, say, 1700 rpms, then it would do it be it in first gear, second, third, you get the picture
You also said that when you hit a certain speed the shaking begins even if you throw in the clutch. THat right there eliminates engine speed
Ask someone to watch the front of your vehicle as you drive it toward them at around 15-20 mph. They should visibly be able to tell if a tire is out of round or looks funny. The same goes for the rear if nothing is seen in the front (except you'll be pulling away from them)
If need be, use the zoom on a video camera or binoculars so you get a closer view
Old Dec 29, 2010 | 07:25 PM
jmilano89's Avatar
and what if its not the tire?
Old Dec 29, 2010 | 07:48 PM
Car: 1990 camaro RS
Engine: 305 TBI
if its not the tire id wanna personally drive it before i say anything else cuz what some1 says and what they mean arnt always the same
Old Dec 29, 2010 | 08:25 PM
welcome to the world of troubleshooting
sometimes you must eliminate what it isn't, to discover what it is. To investigate a tire won't cost you a lick even if you go to a tire center where they want to sell you a tire
apo_bailon15
Mar 28, 2016 05:20 AM
xxx3man`
Sep 23, 2015 10:37 PM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 12:39 PM
86White_T/A305
Aug 17, 2015 12:16 AM
