zero decking? height?
Old Feb 21, 2008 | 06:42 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
what shoul i have the my machinist set the deck height at im runnng kb pistons flat top -7cc
fel pro 1003 head gasket .041
im thinking .002-.003
any sugestions
Old Feb 21, 2008 | 06:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: zero decking? height?
Whatever it needs to get a zero deck.
Old Feb 21, 2008 | 10:40 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
will this affect my pushrod length?
Old Feb 21, 2008 | 10:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not significantly.
Old Feb 21, 2008 | 10:50 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
if any thing a little more lift huh?
Old Feb 21, 2008 | 10:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, it won't change your lift at all.
Old Feb 23, 2008 | 07:14 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
remember to allow room for carbon build up. a rich running motor at idle will add a lot. does not show up right away. also loose pistons rock in the bore. a weekend race motor no problem. a low speed street cruiser = knocky motor.
Old Feb 23, 2008 | 07:38 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
you can keep pistons alittle in the hole, but zero decked would be best for the motor since .041 is a good quench height to have.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
skinny z
Oct 5, 2015 06:23 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
