I have gas in my oil...
Old Apr 3, 2008 | 09:40 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
I have heard that gas in oil can be caused by a fuel pump being bad. Is this true? Or is it from running rich?
Here is the main symptoms:
Strong gas smell in oil
Thin oil
Oil level extremely high.
low oil pressure.
Old Apr 3, 2008 | 10:03 PM
Re: I have gas in my oil...
Yes the oil pump can cause that.
It has a rubber diaphragm; fuel is on one side, the crankcase is on the other.
What you have, is what you get when the rubber wears out.
A fuel pump is like $15 and takes about 10 minutes to change. Not a big deal.
Change the oil too, of course.
Old Apr 3, 2008 | 10:14 PM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
how old is the motor?my motor guy had the same problem in his chrysler (old car)fuel pump leaked right into the base.and blew the motor up
Old Apr 3, 2008 | 10:19 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
Fuel pump.
Old Apr 3, 2008 | 11:40 PM
82Five-O's Avatar
Car: 82 Sport coupe
Thats the crazy part, i just built this motor, has less than ten miles on it.
Old Apr 3, 2008 | 11:41 PM
Car: 91 maro
spend the money and dont get a stock pump.
Old Apr 3, 2008 | 11:49 PM
82Five-O's Avatar
Car: 82 Sport coupe
this is a stock pump and i'm having trouble staying lean as it is.
Old Apr 4, 2008 | 07:08 AM
Fuel pump.
Right. Gotta get my pumps straight.
Thanks!!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
