speedo cable 88 camaro....HELP! lol
Old Apr 10, 2008 | 08:44 PM
Decayed312's Avatar
Car: 88 Camaro T-Tops
Engine: 305 TBI
Axle/Gears: 3.23 Limited Slip
So yeahh, my speedo cable is definitely broke, i got the end off the trans (easy) but the one on the cluster im having a problem with. I know the break is by the trans since i pulled on the cable and out cable a line bout 5 inches long lol up by the brake lines and steering column theres a coupler... is that made to come off or what im trying to freaking get it out but i just cant find the right angle to get it out. so i guess maybe someone can tell me like in descriptive detail on how to remove it... cus im clueless. i mean i cant even pull the cluster out far enough to get my hand behind it to remove the cable from that... PLEASE HELP lol
Old Apr 11, 2008 | 12:13 AM
tekkitan's Avatar
Car: 87 IROC-Z
Re: speedo cable 88 camaro....HELP! lol
you either need to reach in from underneath where the steering column is, or do what i did and unscrew the gauge cluster and pull it out so you can get to the cable. then there is a little tab where it connects to the cluster that you push down on and it comes right out.
Old Apr 11, 2008 | 06:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following link will provide some info about removal:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Apr 11, 2008 | 12:29 PM
tekkitan's Avatar
Car: 87 IROC-Z
i just got the one end off my trans, look at this
Old Apr 11, 2008 | 05:17 PM
Decayed312's Avatar
Engine: 305 TBI
mine looks like that. Unfortunately no one here carries the right one so i had to go to the dealership. they gave me a one line system instead of the 2 thats on there.. ran me 60 bucks plus a 100mile trip just to get it today....
Old Apr 11, 2008 | 10:17 PM
tekkitan's Avatar
Car: 87 IROC-Z
ouch! i havent gone to get another one yet. i hear the one from autozone is also one piece and is a bit of a tight fit (little short)
Old Apr 11, 2008 | 10:48 PM
Decayed312's Avatar
Engine: 305 TBI
yeah its one piece mine had to be dealership like i said but if u have it locally thats better. Autozone, Murrays, and Advance Auto Parts didnt have it. If they did itd have been like 15 bucks.. oh well at least its "GM Genuine" lol but just finished it all up. Since it was one piece i just cut the old wire to slide it out then used a wire hanger to pull it through the dash and wire and all that to get it to the cluster. that made it ten times easier but now it works and its a lot better. Noticed before it broke that it used to float around, guess that was a sign. Anyways jobs done now! Thanks for everyones input.
Old Apr 12, 2008 | 05:08 AM
JamesC's Avatar
Just noticed that it does float as i drive.
Did you clean the housing and lube the cable?
JamesC
Old Apr 12, 2008 | 10:01 AM
Decayed312's Avatar
Engine: 305 TBI
cable was new, didnt need lube, it rotated smooth. I asked the guy at the dealership he even said I shouldn't need to since its new. and ya i cleaned the housing
i need to clarify something. it floated before it broke sorry. i re read what i originally put and i understand i was an idiot on how i worded that lol so i fixed it lol
Old Mar 16, 2013 | 05:25 PM
curtalert89's Avatar
Car: 91 Camaro R/S
Engine: Tbi 350
Transmission: auto4
Axle/Gears: Stock
Okay so my original speedo cable broke a couple months back, I replaces it yesterday with one from Autozone around 5pm, and I was driving to the local salvage yard to pick up a headliner for my car and my speedo quit working again. What would cause the cable to keep breaking?! I have a 1yr warranty on it so I going to pick up another cable here in a bit, but I want to fix whatever It is that's causing the cable to break so I don't have to replace it every 24hrs.
Old Mar 16, 2013 | 05:55 PM
JamesC's Avatar
I'd give a quick check to the cable/speedo head connection. If the cable wasn't clipped into place, it may have come free from the head.
JamesC
Old Mar 16, 2013 | 06:36 PM
Car: 91 Camaro R/S
Engine: Tbi 350
Transmission: auto4
Axle/Gears: Stock
Checked it, it's still clipped in by the little lock piece
topteam54
Oct 6, 2015 12:21 AM
WejaZ28
Oct 3, 2015 07:38 PM
customblackbird
Oct 1, 2015 04:30 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
TrevinE
Sep 14, 2015 03:20 PM
