What intake manifold can I run to clear stock hood?
Old Apr 18, 2008 | 10:00 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I have a 91 firebird formula with the base hood. No cowl or nothing. I'm trying to maintain a stock look. I'm running the performer RPM right now with a Holley 650 DP and a 14 x 3 drop base air cleaner and it just clears. My combo would really love a single plane. Are there any single plane intakes that I can run that will clear my stock hood?
Old Apr 18, 2008 | 10:19 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: What intake manifold can I run to clear stock hood?
I think some of the Holley/Weiand intakes are single plane, short rise intakes.
Stealth might be one. You'll have to dig into Holleys website. Do you think your combo wants the single plane for the common plenum (how would you know that?) or the single plane for the tall vertical shot (likely, and impossible in your situation )
Old Apr 18, 2008 | 10:58 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
Victor Jr. will clear.
Old Apr 18, 2008 | 11:06 AM
Car: 91 Firebird
Engine: Turbo 355
Is that what you run? I want to make sure because I need to keep the stock hood. It wants to rev and the performer RPM is maxing out I think.
Old Apr 18, 2008 | 11:31 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Yes, that's what I run. It fits, barely.
Old Apr 18, 2008 | 11:39 AM
Sonix's Avatar
Car: 1982 Trans-Am
Really??? Wow, that must be a tight squeeze.
have you thought about cutting down your divider wall? I think nightrider87 did that and swears by it. Enlarges the plenum slightly etc.
Old Apr 18, 2008 | 12:02 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I have done that on several motors I have built. It helps out a great deal!
Old Apr 19, 2008 | 05:01 AM
Pat Hall's Avatar
One possible suggestion for a single plane intake would be the Weiand X-Celerator #7547. I run the 7546 on my 69 Camaro, and it pulls to 6k no problem. The 7547 has a similar rpm range according to Weiand, but it's a low-rise design. My 7546 is probably about the same height as your Performer RPM, so it'd more than likely work, but I'd say the 7547 would fit for sure.
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
