Seized o2 sensor
Old Jul 6, 2008 | 01:18 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Seized o2 sensor
Is there anything I can spray around the o2 sensor to help loosen it? I tried WD-40, no luck. This thing has probably been in there since the car was new. It's actually broke off and there is no telling how long it has been that way. Someone mentioned heating up the exhaust to get it out, but if I did that I wouldn't be able to get my hand up in there.
Old Jul 6, 2008 | 01:26 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: Seized o2 sensor
the only way is to heat it up using a torch until its glowing all around the just knock it loose with the tool and youll be fine.
Old Jul 6, 2008 | 02:39 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
i had that problem with my 86 acura, what u have to do is try using penetrating oil from inside the manifold if its possible if not outside is good too, just spray it then try to loosen it if it doesnt budge try tightening it to get all the oil in it. you could also try a breaker bar, but use a 6point socket not a regular one, because if u use a regular socket u run the risk of stripping that sensor and then the only way to get it out will be a plasma cutter. dont ask how i know.
Old Jul 6, 2008 | 05:00 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
heat and lots of it!
Like mentioned above, get it glowing cherry, give it a smack, and it will spin right out
Old Jul 6, 2008 | 05:14 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
I soaked it with PB Blaster for an hour and it worked. I nearly broke my fingers when it finally came loose, but at least it's off so i'm happy.
Old Jul 7, 2008 | 06:14 AM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
PB Blaster worked on mine too. Also used a long breaker bar with six point socket.
Old Jul 7, 2008 | 08:36 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
heat it and tap with a brass hammer
lightly
Old Jul 7, 2008 | 11:40 AM
Engine: LO3
pb blaster works sometimes depends how well its rusted in there. when in doubt use the heat though you can even combine that with pb.
Old Jul 7, 2008 | 11:44 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
dont use wd40 use only PB blaster if that dont work try taking it off hot
v8_musclehead
Jan 25, 2020 05:18 AM
thatdavidkid
Jan 13, 2012 07:56 PM
91camarosRS
Jun 22, 2010 09:06 AM
Anniversary-Z-man
Jul 24, 2004 08:09 PM
BanditWS6
Jan 17, 2004 10:40 AM
