Need to order new injectors tommorow, in need of help
Old Jul 11, 2008 | 10:02 PM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
Hey, well all 8 of my fuel injectors need to be replaced (stock ones), apparently they got a heavy dose of ethanol somehow and it ruined them so they all leak/stream and thats what caused my entire block to be flooded with gas
my auto guy said he can get them @ 150$ a piece O_O
im looking to find them cheaper online and just have him put them in. Fuel injectos are something i dont know alot about can anyone point me in the right direction as far as best replacements for the stock ones i can get for the lowest price?
i was looking at the airtex ones on rockauto.com but i am not sure if they are correct
88 Trans Am GTA 350 TPI auto btw
Thanks!
Old Jul 12, 2008 | 04:09 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Need to order new injectors tommorow, in need of help
i think this would be a good place to look,
http://fuelinjectorconnection.com/shop/
Old Jul 12, 2008 | 02:09 PM
ughmas's Avatar
thanks for the link but that doesnt really help me cause i dont know what im looking for :\
i need to order asap
Old Jul 12, 2008 | 04:58 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
Thanks!
350 TPI?
You may wish to check here.
http://www.fiveomotorsport.com/Injec...sTPI.asp#caddy
Old Jul 13, 2008 | 02:30 PM
ughmas's Avatar
Originally Posted by Cat59
350 TPI?
wow thanks so much, you just saved me hundreds of dollars, i orded a set of 8 for 305$
thanks again
Old Jul 13, 2008 | 05:22 PM
Cat59's Avatar
You're welcome. Glad I was able to help.
Old Jul 18, 2008 | 08:51 PM
ughmas's Avatar
well i got them in today and my mechanic tells me they are different and will not work.. even though the website says 1985-92 Firebird 5.7, and the guy i talked to on the phone said they would work
mine look like this
the ones they gave me are shorter and the top is different
anyone know where i can get the correct ones that look like this for a good price?
Old Jul 18, 2008 | 09:08 PM
ughmas's Avatar
found another pic and description of which injectors they are, now i just need to find them to buy 8 of them ...
87-88 Vette RP 5235302 5.7L TPI injectors -- (Bosch design with aluminum tip)
Old Jul 18, 2008 | 09:42 PM
DENN_SHAH's Avatar
took me about 30 seconds to find these on the site i first posted up,
http://fuelinjectorconnection.com/sh...&productId=134
Old Jul 18, 2008 | 09:46 PM
ughmas's Avatar
those dont even look close to right
not to mention they are more expensive than the OE acdelco RP ones
Old Jul 18, 2008 | 11:52 PM
DENN_SHAH's Avatar
i have to ask, did you read what is said on that site?
from the site, "These are the new style Bosch Design III fuel Injector." so yes, they do not look like the old multecs.
"DIRECT FIT, THESE HAVE THE SAME INSTALLED HEIGHT AS THE MULTEC INJECTOR."
"WE HAVE MODIFIED OUR MOUNTS SO THEY FIT EXACTLY AS ORIGINAL. OUR COMPETITORS ARE 1/4" SHORTER."
"These have been rebuilt using vito o-rings and heavy duty filter baskets."
in your first post you said $150.00 each for stock injectors, these are $169.95 plus shipping for a full set.
Old Jul 19, 2008 | 12:41 AM
ughmas's Avatar
sorry im just skeptical after buying a set that said they would work for my car and having them be wrong,
so these will fit exactly the same as the one i have pictured above? i just want to be sure, and it doesnt say per set for that injector, are you sure the 169 is for a set of 8? ill probably call them tommorow to be sure.
oh and one more note of why i think those are wrong
the 5235302 orignal ones that were in the car are listed as MPI not multec, and it is described as:
SAME INSTALLED HEIGHT AS THE MULTEC INJECTOR., but my car didnt have the multec's
i also found the original ones that i am looking for the RP 5235302 listed on http://www.injectors4u.com/injector_prices.htm ill call and ask them if they have 8 of them tommorow
Old Jul 19, 2008 | 04:34 AM
DENN_SHAH's Avatar
no problem.
even though they are a little shorter, the injectors you bought would probably work just fine. many people here have used them with out a problem. a search for SVO ford injectors will turn up a good number of posts.
but i can tell you as a professional mechanic, if someone brought a set of injectors for me to install that were shorter than the originals, i would not put then in. its has to do with liability.
GM used a couple of different types of injectors in the TPI cars.
the early type were a pintle design & were very prone to clogging & leaking. many times the standard way of flushing them didn't work & required they be replaced.
if a flush that was strong enough to actually clean them was used, most of the time the injectors would short out internally.
somewhere around 88 or 89 GM came out with the Multec injector which used a ball design & was a much better injector. they don't clog up nearly as bad & are much less likely to leak. an injector from a 85 TPI is the same length as one from a 92.
but the multecs also have a problem. just like the earlier design they flow the fuel around the windings to help cool the injector, but additives in gasoline & many injector cleaners can cause the insulation to break down & the injector to short out.
alcohol is a major player in this problem. as far as i know, all pump gasoline has some alcohol in it.
many of the newer types of injectors don't flow fuel across the windings. they also atomize the fuel better. thats what the Bosch Design III injectors are.
all TPI motors are Multi Port Injection or Multi Port Fuel Injection, or the short way, MPI or MPFI. its the type of injection system used. it means the injectors are mounted near the heads & have 1 injector per cylinder.
so you know, the injectors i posted are not brand new injectors, they are used.
also, the injectors from the place you just posted are not new injectors either.
to be honest, if you put a set of those stock rochesters back in, your putting the same poorly designed injector in that you have now.
Old Jul 19, 2008 | 01:47 PM
ughmas's Avatar
no problem.
so what your telling me is to get a newer injector?
should i have him put the ones i bought in? or buy those bosch design III's?
i just want to know if the design III's will fit right and he can put them in without complaints, i guess i could just print out your post or something.
these are the ones i have now, im about to send them back though, he said they wouldn't fit though because of the clip on the top slot
http://www.fiveomotorsport.com/Parts...Takeouts_8.jpg
thanks for the explanation, appreciate it, looking forward to hearing your final word
Old Jul 19, 2008 | 02:05 PM
ughmas's Avatar
well i just called the place i got mine from and he said to have my mechanic call him because they WILL fit and work correctly, (basically saying my mechanic is an idiot lol) but he said he would walk my mechanic through it on monday, so i guess ill try that first before i buy any other ones
Old Jul 19, 2008 | 04:09 PM
DENN_SHAH's Avatar
i wouldn't say your mechanic is an idiot, i completely understand why he is hesitant about using those injectors.
the injectors you have should work. they are the same ones that a good number of people here have in their TPIs. i would have thought some of the people who have them would be posting up in here.
a couple of points, there has been some debate about which ford injectors are the right drop ins for a stock 5.7, the yellow tops or the pink tops.
there has also been some talk about the o-rings that come with the ford injectors, they may need to be swapped out with some GM O-rings.
the injector retaining clips do need to be used to keep the injectors in the fuel rail, without the clip the fuel pressure can push them out resulting in a big fuel leak. using
the retaining clips is true for the stock injectors too.
a few posts about using the ford injectors,
https://www.thirdgen.org/forums/tpi/...injectors.html
https://www.thirdgen.org/forums/tpi/...ctor-swap.html
https://www.thirdgen.org/forums/tpi/...d-know-if.html
i would think with the number of questions asked & as much debate as there has been about injectors, there would be a sticky covering them.
with the increase of alcohol in gasoline, maybe its time for one.
Old Jul 19, 2008 | 04:11 PM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
I plan on buying those same Bosch III. Let me know what type of special instructions to install and how you like them once there on!! GREATLY APPRECIATE IT!!!
Old Aug 25, 2008 | 07:46 PM
jam019's Avatar
Car: 90' Corvette
Engine: 355
Transmission: 700r4 2800 stall
Axle/Gears: 3.07
He's not going to give you a refund, He's a jerk ask me how I know.
Jorlain
Oct 8, 2015 01:57 AM
BAMiller
Sep 14, 2015 06:38 PM
fasteddi
Sep 10, 2015 09:32 AM
TheTraut88
Sep 7, 2015 05:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
