Carb On - Still Won't start
Old Aug 6, 2008 | 02:23 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I just put on my third Qjet electronic carb. I was told the first were dumping gas. Car would run for a few days then won't start.
I switch carbs but still seems as if there is no spark. Car had recent tune up just prior to this problem.
Gas is only getting up to the fuel filter but nothing in the bowl.
Any ideas? Is something plugged. Oh and if I put gas in the carb still no start. Car just turns but no fire.
Old Aug 6, 2008 | 02:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Carb On - Still Won't start
Have you checked for spark?
Old Aug 6, 2008 | 03:18 PM
Axle/Gears: Posi
No I have not. I thought I should get gas in the carb first. What should I do first? How do I get the spark? Right now I have no backfire or anything.
Old Aug 6, 2008 | 03:23 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
do you have an inline filter if so id check to see if maybe you accidentally put it on backwards I've seen it done before
Old Aug 6, 2008 | 03:24 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
The only way your car will get gas to the carb is to have the mechanical fuel pump operating. It will only work by energizing the starter to turn the flywheel/flexplate or the engine is fired up. I suspect something happened during the tune up. Check for spark as Apeiron stated.
Old Aug 6, 2008 | 03:41 PM
Axle/Gears: Posi
Originally Posted by 86z/92rs
The only way your car will get gas to the carb is to have the mechanical fuel pump operating. It will only work by energizing the starter to turn the flywheel/flexplate or the engine is fired up. I suspect something happened when during the tune up. Check for spark as Apeiron stated.
Thanks. Where should I check for spark from first?
Old Aug 6, 2008 | 03:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Anywhere you like.
Old Aug 6, 2008 | 07:51 PM
Axle/Gears: Posi
I am wondering if I might have a timing chain problem?
Old Aug 6, 2008 | 09:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not especially likely, but possible.
Old Aug 6, 2008 | 09:52 PM
Axle/Gears: Posi
I could only pour gas through carb. Gas gets to the fuel filter. Manual fuel pump I believe. I was able to get the car to run briefly until any gas in carb ran out. The distributer seemed out of line. And that got me to thinking if the timing chain teeth are gone. Somene installed this engine and I thought they changed it but maybe not.
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
cstrobel65
Aug 15, 2015 10:19 AM
