IAC Valve
Old Sep 6, 2008 | 06:20 PM
Dean_GTA's Avatar
Car: 1988 TA GTA
Engine: L98 Replaced w/ 350/330HP W/TPI
Transmission: Stock 700r4
Axle/Gears: stock 3:27
IAC Valve
I changed my IAC a while ago. I just screwed it into the throttle body. Some people have told me that I need to set/adjust it. Is this true? If so How do you set/adjust it?
Old Sep 6, 2008 | 06:43 PM
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
Re: IAC Valve
read this it was very helpful when I changed my IAC valve
http://www.iroczone.com/techarttpsadj.html
I think there is also a tech article here on TGO...might want to use the search feature...
Old Sep 6, 2008 | 07:24 PM
Dean_GTA's Avatar
Car: 1988 TA GTA
Re: IAC Valve
The car had a hesitation before I changed the IAC and it still does. Is this setting a must do when changing the sensor?
Old Sep 6, 2008 | 09:13 PM
Re: IAC Valve
if by sensor you are reffering to the IAC valve then yes you do need to adjust it..and check the OHMs on your TPS sensor....make sure to check that the TPS's ohms arent jumping around it when you open it to WOT the resistance should steadily and smoothly increase..if the resistance isnt steady then you in fact have a faulty TPS sensor
Old Sep 6, 2008 | 11:19 PM
CamaroRider's Avatar
Re: IAC Valve
I do not think you can 'adjust' the IAC. I believe it will automatically readjust when you are running the engine. I think the ECM will close the IAC when the car is started and then deal with it as needed. There are some indications that the engine might need to be run for a few minutes to properly function after it has been removed and replaced.
Old Sep 6, 2008 | 11:41 PM
Re: IAC Valve
dope!..stupid me I worded that incorrectly...yea the IAC adjust itself..but you need to adjust your idle when you first installl the new one (read this page http://www.iroczone.com/techartidle.html )....the computer needs to recognize the new part so it may take a few minutes of driving and clearing the ecm by unplugging the battery for about 5 min....like ive stated before yoiu should take an voltmeter and check your TPS sensor as well..loosen the TPS until you can move it up or down slightly and then turn the key to "on" position but dont crank it, then insert the positive and negative leads into the tps sensor and adjust the position of the sensor until youre at the sensor's spec resistance...then tighten the tps in the position where it was closest to spec...now you should be closer to being done and crank it up and see if it idles correctly....
Old Sep 7, 2008 | 12:17 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: IAC Valve
Yes, the ECM resets the IAC on startup, but it uses the installed position for a zero reference point. There's nothing to tell the ECM when the pintle is completely retracted/extended that's why it needs a reference point.
First you have to determine which type you have because each type retracts differently.
  1. Retract the valve completely into the IAC motor body.
  2. Install IAC valve in throttle body using new gasket. Torque IAC valve to 13 ft. lbs.
  3. Connect IAC valve electrical connector.
  4. Start engine and allow to reach operating temperature.
  5. The ECM will reset the valve when the engine is started, then the ignition is switched off.
Old Sep 7, 2008 | 12:27 PM
Re: IAC Valve
I just removed, cleaned and replaced my IAC and the steps were the same as 'rgarcia63' states. When I started the car it was a cold engine. It idled at a normal cold idle speed (a little high) and the engine gradually came up to normal running temperature. The engine speed dropped as you would expect but the idle seemed a little higher than what I would normally experience for a warm idle (it was). I shut the engine off for about 30 seconds and decided to see where it would idle when I restarted it at normal running temperature. When I started the engine it quickly went down to the idling speed I normally experience. All subsequent restarts did the same (idled well in my opinion).
Old Sep 8, 2008 | 09:54 AM
yuqingeng2007's Avatar
juesting29
Nest and Hair My sister, a primary school teacher, was informed by one of her pupils that a bird had built its nest in the tree outside the classroom. "What kind of bird?" my sister asked. "I didn't see the bird, ma' am, only the nest," replied the child. "Then, can you give us a description of the nest?" my sister encouraged her . "Well, ma'am, it just resembles your hair. " dyestuff
Old Sep 8, 2008 | 10:50 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: IAC Valve
here is thirdgen's writeup on IAC and TPS adjustment. its in the technical articles section. i highly recommend that you check it out, there is alot of good information on there.
https://www.thirdgen.org/tpimod2
Old Jul 23, 2017 | 02:37 PM
mjwadams's Avatar
Car: 92 RS
Engine: L03 with Holley Sniper EFI, headers
Transmission: T-5, hurst billet shifter
Axle/Gears: 3.08 posi
Re: IAC Valve
That link is broken now, but there are couple of others which still work.
http://www.iroczone.com/2009/10/adju...ir-idle-speed/ and http://www.iroczone.com/2009/10/clea...rol-iac-valve/
Old Jul 23, 2017 | 02:42 PM
mjwadams's Avatar
Car: 92 RS
Re: IAC Valve
That link is broken now. I found a couple of similar links but this original can still be found on the wayback machine:
https://web.archive.org/web/20080724...arttpsadj.html
92firebirdguy
Sep 1, 2016 07:53 AM
sandman92084
Sep 12, 2015 10:27 PM
earlpote
Sep 12, 2015 11:55 AM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
