anyone have their smog for a 350 TPI l98 still on?
Old Oct 14, 2008 | 10:49 PM
85z28LT1's Avatar
Car: 1985 Camaro Z/28
Engine: 5.7L 350TPI
Axle/Gears: stock 3:42 open
I need to reconnect mine just up to the cat to pass inspection. anyone have a picture of the passenger side of their engine bay? all the ones i find have the A/c on the passenger side and the alt on the drivers(mine is the other way) I need to see how the hose routes back to the cat. I tried searching here and google but I cant find a good picture, plus I have a 85 z28 that has the L98 in it, but i just need a picture if anyone has one or could be so kind as to take one I would appreciate it
Old Oct 15, 2008 | 01:50 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: anyone have their smog for a 350 TPI l98 still on?
From the air pump, there is a metal line to the AIR diverter valve. That has two plastic fittings out the back to two rubber lines. One rubber line goes to a T fitting which splits between the passenger side and driver side AIR tubes on the manifolds. The other rubber line connects to a metal line which goes down the back of the engine and along the Y-pipe to the connection on the cat.
Old Oct 15, 2008 | 10:10 AM
85z28LT1's Avatar
Engine: 5.7L 350TPI
Okay, well I dont have to connect it to the manifolds I just need to put it to the cat, so the metal tube that sits in the engine bay on the passenger side goes back towards the cat? it looks like it goes around the back of the engine.
basically i just need to put a belt on the pump and run pipe to the cat, and that metak tube is the pipe for the cat? mind you this is on an 85(idk if it chagned
Old Oct 21, 2008 | 02:27 AM
Kevin91Z's Avatar
There are two of them. One goes behind the engine to the driver's side manifold.
The other goes behind the engine to the cat.
Old Oct 21, 2008 | 11:37 AM
85z28LT1's Avatar
Engine: 5.7L 350TPI
so there are two metal pipes? I only see one
Old Oct 21, 2008 | 02:25 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
On my 89, there is only 1 metal pipe. The exhaust manifold gases are connected by a thick rubber hose that goes behind the block. The metal line goes down the back of the passenger side to the cats.
Here is an old pic of my engine: http://redformula.com/Firebird/Rebui...d/DSC00912.JPG
I have several pics on the site that might help... feel free to look around.
Hope this helps!
Old Oct 22, 2008 | 10:24 AM
85z28LT1's Avatar
Engine: 5.7L 350TPI
Hope this helps!
helpful but I cant see what I am looking for. why is it all the other 3rd gens I see have the alternator on the drivers side and the A/c on the passeneger. while mine is opposite?
Old Oct 23, 2008 | 07:48 PM
Kevin91Z's Avatar
1988 was the only year I know of that had a metal pipe around the back of the engine to the driver's side exhaust manifold. The other years had rubber lines.
82-87 engines have v-belt accessories, with the A/C on the driver's side and alternator on the passenger side. In 1988, GM came up with the serpentine accessory system, using only one belt for everything, and switch the A/C and the alternator.
Old Oct 23, 2008 | 09:19 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
okay so I just need a long rubber hose to go the the cat, awesome. I appreciate the help! saves me some troubles
Old Oct 23, 2008 | 10:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need high temp green hose going down to the cat.
Old Oct 23, 2008 | 11:30 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
does it really matter when it will only be on there for like 5 min?
Old Oct 23, 2008 | 11:45 PM
five7kid's Avatar
It doesn't matter if you like the smell of smoking rubber hose.
Old Oct 24, 2008 | 12:09 AM
85z28LT1's Avatar
Engine: 5.7L 350TPI
lol I assumed that black rubber hoses were high temp too.
Old Oct 24, 2008 | 08:30 AM
kahless's Avatar
Car: 89 Firebird Formula
Engine: chevy 5.7 V8 TBI but carbed soon
Axle/Gears: no freakin clue lol
I just ripped all of mine off. Check my post winter project. I posted pics before i removed it.
Old Oct 24, 2008 | 11:32 AM
Kevin91Z's Avatar
No, the rubber hose went around the back of the engine to the driver's side exhaust manifold.
There is a metal line that goes down the back passenger side of the engine to the cat.
Old Oct 24, 2008 | 12:44 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
ohh I thought you said the metal hose goes to the other side. where does it come out in relation to the cat?
Old Oct 27, 2008 | 12:49 PM
Kevin91Z's Avatar
It follows the Y-pipe down to the cat and enters the middle of the cat.
Old Oct 27, 2008 | 04:50 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
so I should be able to just jack the car up and see it down by the y-pipe?
Old Oct 27, 2008 | 10:01 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Yea you have to fish it up from the bottom or down from the top. I forgot how I did it. I think I bought mine from rockauto.com for under $20.
I have a question for you smog guys. Is there a bracket to support the diverter valve? Any pics of it? I'm getting ready to install mine too.
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
