Speedometer
Old Oct 25, 2008 | 09:20 PM
72SSboy's Avatar
Car: 1988 IROC-Z
Speedometer
Hello --
I must be some kind of an idiot. Here's why.. the needle on the speedometer on my 88 IROC 5.7 is not springing back. The spring is obviously shot.. so, when I take off.. going whatever slow speed.. the needle goes where-ever it wants. Just bounces around like crazy. I got another speedometer on ebay.. that does spring back into place properly. I CANNOT figure out how to get the original speedometer out.
I took the plastic cluster cover off.. then the plexiglass.. then the metal cover off of the actually guages. I see screws around the voltmeter, gas guage, temperature guage.. but, not around the speedo. Please tell me how to get it out and put the working one in.
j
Old Oct 25, 2008 | 09:28 PM
82CAMAROBBC's Avatar
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
Re: Speedometer
did you remove the spedo cable on the back of the cluster? You have to do this from under the dash.
Old Oct 25, 2008 | 09:37 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer
The following thread should provide the info you require (and more):
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Oct 25, 2008 | 09:42 PM
72SSboy's Avatar
Car: 1988 IROC-Z
Re: Speedometer
thanks for the replies guys.. I see the pics.. great. So, I have to pull the entire white housing out with the guages. Do I need to undo the speedo clip before I pull the housing? Or can I get to it as I'm pulling it out. It appears I have to access it from underneath.
Maybe a better question.. this speedo appears as though it would work.. just need to get that spring to tense up again.. anyway to just replace that?
thanks
j
Old Oct 26, 2008 | 07:05 AM
JamesC's Avatar
Re: Speedometer
Yes, you must pull the entire housing. Yes, you need to undo the clip beforehand. Access it from underneath. Sounds like the speedo head has expired.
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
