In theory...
Old Oct 30, 2008 | 10:59 AM
10secondhopeful's Avatar
Car: '84 Z28
In theory...
Could you bore and stroke a 305 to a 383. Technically its the same block as a 350 but with a smaller bore and stroke. So if you did some serious boring so 4.030 then slapped a 3.750 stroke on it you'd have the 383. what do you guys think?
Old Oct 30, 2008 | 11:01 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: In theory...
You can't bore a 305 far enough. And why? for what it would cost you, you can get a 350 block. If you're having trouble finding one, just tell us.
Old Oct 30, 2008 | 11:36 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: In theory...
No, they're not the same blocks. They're different castings.
Old Oct 30, 2008 | 11:57 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: In theory...
To put a 3.750" stroke crank in a 305 block would require custom pistons, probably about $800. At that point, it's cheaper to just build a real 383.
Old Oct 30, 2008 | 12:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: In theory...
No, they're available off the shelf.
Old Oct 30, 2008 | 12:54 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: In theory...
oh... i just assumed they wouldn't be readily available. Seems like an odd combination, to put a 3.750" stroke crank in a 305 block.
Old Oct 30, 2008 | 01:10 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: In theory...
at 30 over, you get a 334. but why bother?
Old Oct 30, 2008 | 01:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: In theory...
You can also do it more cheaply with a standard run-of-the mill 305 piston if you use a 5.565" rod. Doesn't make it any less of a complete waste of time and effort, though.
Old Oct 30, 2008 | 08:06 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: In theory...
If I recall correctly, the 305 block has water jackets close to the cylinders to dissipate heat, just like a 350 does, which is what limits how far you can bore an engine.
Just get a 350 block. A 1 piece roller block should run you $200 used. If you're not in a hurry, just wait. One will show up sooner or later.
Old Oct 30, 2008 | 08:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: In theory...
All water-cooled blocks do.
Old Oct 30, 2008 | 08:15 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: In theory...
Old Oct 30, 2008 | 09:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: In theory...
3.75 stroke in a 305 makes a 334 when bored .030 over. Not a bad little motor, it has potential but not as much as a 383, atleast i havent seen ppl bulid a very stout 334, naturally aspirated. And i mean 11 second car as 383 with any good set of heads and a medium hyd.roller cam should be a 11 second car with a decent intake setup (ie not LTR TPI)
lucky14
Mar 6, 2009 07:00 PM
lucky14
Mar 6, 2009 06:55 PM
forkvoid
May 26, 2007 02:24 PM
z_power
Jan 14, 2004 10:28 AM
Bry in Virginia
Oct 22, 2000 09:55 PM
