Which one is a cheaper upgrade?
Old Dec 2, 2008 | 12:20 PM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Sup,
I was wondering which upgrade would be the cheapest in the $100-$200 range that would return the most power.
I found headers on ebay for ~$100.
Any idea how much a bolt-on carb would be? One that doesn't need much modification.
The engine I have is an electric carbed 350 chevy. The headers I have on are carried over from my original 305 (pretty crappy condition). The carb is throwing bad codes (I think because whenever it chokes and studders, the "fasten seatbelt" light turns on). It is the stock one from the original engine. It's been rebuilt quite a few times, but it still sucks.
Thanks for any input.
Old Dec 2, 2008 | 12:29 PM
Car: 82,83,99 T/As
Engine: 350,350,383
Old Dec 2, 2008 | 01:16 PM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
Re: Which one is a cheaper upgrade?
Intake and exhaust are the best places to start…. And umm sfc are always a good idea…
Old Dec 2, 2008 | 01:19 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
hooker or headman shorties and a custom 2.5'' y-pipe made correctly to be able to remove starter w/ease is my vote!
Old Dec 2, 2008 | 02:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Unless you're making more than 500 HP, you won't get more power out of a carb swap.
$100 eBay headers sounds like an expense waiting to happen.
Old Dec 2, 2008 | 08:48 PM
Car: 82,83,99 T/As
Engine: 350,350,383
what would you recommend that's easy to put on?
what would that run me?
what if my carb is complete crap? (drinking gas- 13 h/c mpg @ ~65mph, no power- 0-60 in 10-11s)
i am a little shakey on those headers...
any other ideas?
thanks guys
Old Dec 2, 2008 | 09:01 PM
five7kid's Avatar
It's probably not the carb's fault, or would be less expensive to fix than putting something else on.
Old Dec 3, 2008 | 02:50 AM
burn0ut305's Avatar
Car: z28
Not sure what you have already done to it, but it sounds to me like you need a full tune up… take it to a shop that does an inspection with there oil changes… have them take a look at it, and make sure all ur fluids, belts, battery, air filter, and brakes are working good… no point in putting on headers when ur engine isn’t runny at a 100%…
So spend 20 dollars of that 200 on an oil change and have a ASE master mechanic look at ur car!!!!!
Old Dec 3, 2008 | 11:07 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
And if you have any cash left over, either:
1) take your significant other to a steak dinner, or
2) save it towards future mods, or
3) put synthetic lube in the rear axle, or
4) pick up a good used aftermarket intake manifold.
Old Dec 3, 2008 | 04:22 PM
Car: 82,83,99 T/As
Engine: 350,350,383
the oils been changed, the tranny fluid is at the right level, the power steering too, the belts have been replaced, the battery is like a year old, i replaced the air filter with the oil, the brakes stop strong
the problem with having a master mechanic look at the car is because my dad will not agree to it. he trusts his mechanics, and thinks every other mechanics out to rip him off. i'm afraid if i go to one of these mechanics, my dad's going to complain about costly bills. i'm 17 btw.
thanks for your input guys
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
Zell1luk
Sep 29, 2015 10:36 AM
dusterbd
Sep 29, 2015 08:40 AM
