tall valve covers do they fit?
Old Mar 17, 2009 | 05:01 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
does anyone know if tall valve covers fit on the drivers side under the wiper motor and windsheild washer pump. i dont know how much taller they are than the short ones but im not sure how much more room i have.
Old Mar 17, 2009 | 06:24 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: tall valve covers do they fit?
ive got tall ones on mine. I had to slightly "modify"the pass side by the ac.the only prob ive had is taking them on and off whenthe stb is on.
Old Mar 17, 2009 | 07:17 PM
Car: 85 trans am
Engine: 383 stroker
i have an ac delete box so pass is no problem. what do you mean with the stb on?
Old Mar 17, 2009 | 08:26 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
strut tower brace. the short valve covers could manipulated fairly easy without taking the stb off. but with the tall covers and the stud girdles on it was almost impossible to get them off without removing everything.
Old Mar 17, 2009 | 08:32 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Tall valve covers will fit, you just have to watch if you still have your emissions equipment on the passenger side because the box with the air pump will not fit. I ended up cutting the metal pipe that goes to the emissions pump and using a rubber hose to extend the box higher to clear the valve cover.
Old Mar 17, 2009 | 08:43 PM
Car: 85 trans am
Engine: 383 stroker
i have already pulled out all my emissions stuff and plugged up my AIR line on my headers so that wont be a problem. so it sounds like they will work without any problems. i dont have a strut brace but i plan on getting one in the future when i get around to my suspension list. so that will be a problem later. but hopefully once the strut brace is on i will be done for a while pulling valve covers. one reason i chose to stay hydrauic flat tappet when i picked my cam.
Old Mar 18, 2009 | 04:25 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Technically they fit. I ended up trimming my wiper gear box in order to make install and removal a bit easier. Couldn't seem to find a smaller setup that would fit our cars.
Old Mar 18, 2009 | 03:31 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Mine fit fine.
The wiper motor is snug, but that's about it.
Old Mar 18, 2009 | 06:03 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
not to jack your thread.. but kinda goes with the subject..
Has anyone tried the proform 2pc tall valve covers? They look a little bigger than regular v/c.
www.jegs.com/i/Proform/778/141-913/10002/-1
Old Mar 18, 2009 | 06:35 PM
Car: 85 trans am
Engine: 383 stroker
thats ok i am curious too
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
