Head bolt torque?
Old Apr 4, 2009 | 09:09 AM
AC's Avatar
AC
Car: Used to drive a camaro
Head bolt torque?
Not as simple as that really (I think). Here's the scenario. I have ARP head bolts and Dart aluminum heads. Dart and ARP ALL have different #'s they're saying for torque. I understand the aluminum expands differenlty than iron so the torque will be lower. ARP is saying 60ft lbs, but Dart are saying 70ft lbs.
I need some direction here. I don't feel like blowing head gaskets on this new motor.
Old Apr 4, 2009 | 09:12 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: Head bolt torque?
65ft/lbs
Old Apr 4, 2009 | 09:31 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
wow 3 minutes and he gets an answer. i case i have to do the same thing later can you let us know where you got the info, or is it something you remember from doing it in the past. if there is a cart or book or something i would like to save it for later use.
Old Apr 4, 2009 | 09:44 AM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
https://www.thirdgen.org/forums/tech...-sequence.html
I posted this in a thread a while back.
Hope this helps
Old Apr 4, 2009 | 10:13 AM
Car: 1990
Axle/Gears: stock
Hope this helps
that was 3 years ago! yes it helped. i turned that one into a pdf file and put it away for when i put the new heads on.
thanks a lot for that information.
Old Apr 4, 2009 | 10:19 AM
dctrumpet's Avatar
Wow, I didn't realize it was three years ago!!!! That's when we could buy ammo cheap, lol!!!!!
Old Apr 4, 2009 | 11:53 AM
Car: 1990
Axle/Gears: stock
i used to buy 5,000 rounds of 9mm for 200.00 and chi .223 for 3 cents each. those days are gone. it costs a fortune to go to the range and shoot up 400 rounds.
and don't even begin to look at .45 ammo - its through the roof.
Old Apr 5, 2009 | 06:51 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Use the specs the head mfg recommends.
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
