missing a part on engine, what is it?
Old Aug 18, 2009 | 10:01 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Transmission: 700-R4
Axle/Gears: OSD 10 bolt/ 3.42
what goes in this opening?
not my actuall engine, just showing what im asking about
sorry about the extremely small pic, but you should be able to zoom in on it if you double click the attachment window and open it up in a new page
any help is appreciated
-Thanks
Old Aug 19, 2009 | 12:00 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: missing a part on engine, what is it?
That's where a mechanical fuel pump goes, but you don't have to use a mechanical fuel pump, and I doubt you will be using one on your car because there should be a fuel pump in your gas tank. Why the block off plate is missing is a mystery. Did you just get the car or something? If you use an in-tank pump or inline pump, you block off the mechanical fuel pump location with one of these http://www.summitracing.com/parts/SUM-401030/
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Fuel pump on a carbureated engine, block-off plate on fuel injected.
Old Aug 19, 2009 | 12:03 AM
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
That is where the mechanical fuel pump is attached. Refer to the following picture:
http://i184.photobucket.com/albums/x.../fuel_pump.jpg
The picture shows a plate that blocks off the bottom half of the mounting location on the engine. If you use an electic fuel pump, then this mounting location needs to be blocked off with a plate.
EDIT: haha, 2 people replied while I was typing my reply.
Old Aug 19, 2009 | 12:11 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Ha....beat ya to it.
Old Aug 19, 2009 | 03:07 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
thanks for the quick replies
im going to go head and get that part today
-Josh
Old Aug 19, 2009 | 05:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Many EFI engines in the early 90's weren't drilled for the fuel pump push rod or oil drain-back hole, so no block-off plate is needed.
Old Aug 19, 2009 | 05:46 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
hmm, ill have to take a closer look at mine
Old Aug 19, 2009 | 09:45 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yeah my early 90s truck block doesnt even ahve a hole in the block for a fuel pump rod.
hectre13
Dec 11, 2023 08:14 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
