Engine dies when coming to a stop. Suggestions please!
Old Sep 9, 2009 | 09:38 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
It's a 355 that's making decent power and has a Holly 1850 carb, Holly blue fuel pump...........well here's everything:
punched .030" over, line bored, machined, honed, balanced rods and crank
Factory matched Sealed Power Hypereutectic pistons
Hastings moly rings
Melling high volume oil pump
single piece drive rod
Pro Comp Noisey timing gear set
Erson 465/488 cam ( I have the cam card )
3947041 GM heads, 2.02" intake valves, 1.94" exhaust valves, 64cc chambers, with 170 cc runners
The pressed in studs were removed, and tapped for the threaded studs
1.260" O.D. springs with dampers
stamped retainers and keepers
Crane 1.6 ratio roller rocker arms
PBM flat tappet hydraulic lifters
Edlebrock Performer RPM intake
Holley 1850 4 bbl
Holley blue elctric pump
ARP bolts throughout(except head bolts)
Accel performance HEI distributor
Taylor Spiro ignition wires
new plugs
Edlebrock shorty headers
As I come to a stoplight (it's got a 700 trans) the engine bogs down HEAVILY and then dies. It fires right back up and runs great as long as I don't stop. Kinda like "It only hurts when I'm not sleeping." And thought's please? I can take pics of anything too. Thanks guys.
Old Sep 9, 2009 | 11:50 AM
fleetmgr's Avatar
Re: Engine dies when coming to a stop. Suggestions please!
Will it idle if you put it in drive from park?
Torque converter not unlocking, maybe?
Old Sep 9, 2009 | 02:55 PM
Car: '91 LS6/T56/9"
Engine: LS6
It only does it after the engine warms up. I don't think it does it as bad I go from park to drive, but I'll see. What are the possible causes?
Old Sep 9, 2009 | 03:06 PM
fleetmgr's Avatar
What's your idle RPM set at? Could just be set too low.
Old Sep 9, 2009 | 03:18 PM
Car: '91 LS6/T56/9"
Engine: LS6
I haven't changed anything about the idle. The engine just started doing this.
Old Sep 9, 2009 | 05:23 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
maybe the back float is high and is constantly dumping fuel so the engine floods coming to a stop and its not so bad driving.
Old Sep 9, 2009 | 11:29 PM
Car: '91 LS6/T56/9"
Engine: LS6
Old Sep 9, 2009 | 11:30 PM
Car: '91 LS6/T56/9"
Engine: LS6
While driving. Not great, but what the hell.
pimp2303
Jul 27, 2017 02:03 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
