IS MY CAM TOO BIG
Old Dec 18, 2009 | 10:51 PM
tgill's Avatar
IS MY CAM TOO BIG
hey got a 84 camaro it has a 502 cam in it its a 305 someone told me it is too big for the 305 i cant get it to idle right and its burning rich u can tell by the smell idk if i need a new carb or if he is right and the cam is to big plz help thanks
Old Dec 18, 2009 | 11:02 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: IS MY CAM TO BIG
need more info on the engine specs and cam specs
Old Dec 19, 2009 | 09:42 AM
tgill's Avatar
its a 5.0 got a elderbrock performer intake a carter afb carb and the cam was put in when i bought it so all i no is it is a 502 guess thats the gross lift no ac no smog control idk what eles u need to no
Old Dec 19, 2009 | 10:09 AM
Damon's Avatar
Re: IS MY CAM TOO BIG
Would be nice to know all the cam specs at least.
A wild guess..... if it's a flat tappet stype cam (almost certainly is if it's the original 84 motor) then someting with .502 lift would likely be too big. Not only are stock heads and springs not designed to handle any more than about .470" but also that much lift would usually indicate duration somewhere north of 230* @ .050. In short, a lumpy bastard in a near-stock little 305.
Old Dec 19, 2009 | 10:11 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Old Dec 19, 2009 | 10:33 AM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Originally Posted by Stephen 87 IROC
+1
Old Dec 19, 2009 | 04:37 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
If you havn't broke anything yet it must not be to big. I don't know much but what I can tell you for sure is that idle would probably be around 1000, you can kiss an auto tranny goodbye unless you have a huge stall. Besides that, just set timing at around 18* total advance at idle and I think you should be able to start.
No matter what with a cam that big it will smell rich. If your eyes/nose is running and it's hard to breathe, then you're way to rich. You can count on not driving that car again if you don't want to smell like you took a shower with gasoline.
Old Dec 19, 2009 | 05:18 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I don't know what he's referring to with the 502 number. I don't even know if he's referring to valve lift which would be written as .502". Rocker ratio factors into this, too.
So without knowing, at least, the duration and LSA specs I don't have a clue. I could guess, but anybody can do that. It's all about the numbers; the more the better.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 19, 2009 | 06:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yeah sounds like its flat tappet being an 84, but if it was a roller cam and was made by comp cams, the 502 refers to the part number which means 218/224 duration .502 lift on intake or close to it, i cant remember off hand. Its a nice cam for a carbed 305 i think with full supporting mods.
Old Dec 20, 2009 | 12:31 AM
i would check the dynamic compression with a compression gauge. if that cam is .502" lift, its likely making the compression too low to completely burn the fuel. plus you may have coil bind and other things that may have caused engine damage.
Old Dec 20, 2009 | 11:21 AM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
the closest flat tappet is the magnum 292, it checks in at 244* of duration at .050. and it sounds big in a 434.
Old Dec 20, 2009 | 12:38 PM
JakeJr's Avatar
Axle/Gears: 3.07
See what I mean? It's all about the numbers and he's got to post some.
Jake
West Post ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
BOOT77
Sep 5, 2015 03:55 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
