Oil dipstick question.
Old Jan 13, 2010 | 06:10 PM
red30011's Avatar
Is there supposed to be any kind of grommet or o-ring sealing the dip stick tube? Figuring there is,lol. I've had a bad leak for a few days and after looking around I found the valve cover had bolts backed loose. Tightened them down and plan on using some lock-tight on them this weekend, but either way only seems to have cured half the problem.
The motor is a fresh rebuild by a reputable builder so I doubt its the main seal.All the leaking is on the back half of the motor. Which comes back to what I ask at the beginning. What is used to seal the oil dipstick tube?
The motor is a 70s model 350
Old Jan 13, 2010 | 06:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil dipstick question.
There's no seal.
Old Jan 13, 2010 | 09:07 PM
red30011's Avatar
hm..... really didn't expect that answer. Guess I'm gonna have to get a rag and clean the area since i've fixed the valve covers and search for it. Just bugs me since i'm going through about a quart of oil in 3 days. That and the oil I buy is like $7 a quart...
Thanks for the info
Old Jan 13, 2010 | 09:20 PM
vettedreams2001's Avatar
Car: What don't I drive
Engine: 305 tbi
If you're losing that much oil then it's probably a ventilation problem. I'd check PCV.
Old Jan 14, 2010 | 02:47 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Maybe the rings have not sealed yet and you are getting blow by pressurising the crankcase. People have been know to blow the dipstick right out in some bad cases
As noted back sure your PCV sytem is operating correctly
Old Jan 14, 2010 | 06:43 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Check the oil pressure sending unit, on driver side right next to the distributor. Also check knock sensor on pass side of the block towards the back of motor.....
Old Jan 14, 2010 | 07:41 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by J91
check knock sensor ..
Knock sensor goes into the water jacket at bottom of block
Old Jan 14, 2010 | 07:50 AM
J91's Avatar
J91
OK then, haven't looked at one since I trashed my piece of s%&# 305 TPI yrs ago...
Old Jan 14, 2010 | 05:07 PM
red30011's Avatar
hm....don't believe I have a knock sensor. Simple carb set up. Didn't think pcv could cause much leaking but i'll check that. Thanks for the input. I have push in breathers now. I may go ahead an install the little valves and hook it up to the carb
Old Jan 14, 2010 | 05:46 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Need to clean engine and identify exactly where oil is leaking from.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
BDR
Nov 7, 2015 03:05 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Ian Irvine
Sep 4, 2015 08:08 AM
