marine motor into car
Old Feb 8, 2010 | 07:21 AM
trench555's Avatar
I picked up an engine its a complete block and heads that came out of a boat. i need help figuring out if i can put this in my 71 mc. it looks like the flywheel is really thick thats on it now and it also came with the waterpump the motor is new
block C/N 10243880
heads C/N 10239906
the cam is stock but it came with a receipt showing that the cam had been machined for performance
The motor was purchased from a guy that was planning on putting it in his 55 chev he also gave me a new intake and carb for it. i just need as much info as possible as far as being able to put it in the car and what stuff i need. i cant seem to find any info regarding to swapping the boat motor into the car or if its even possible. I do know its a gm 350/5.7 stamped 355 so its stock 30 over and all the info ive gotten is zz4 related and or truck related. any help would be greatly apreciated
Old Feb 8, 2010 | 08:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: marine motor into car
Just double check that the cam isn't set up for reverse rotation.
RBob.
Old Feb 8, 2010 | 12:51 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
All marine waterpumps are short pumps. For any vehicle '69ish or later, (except for a 'vette) you need a long water pump, if you want to use the stock accessories and brackets.
Old Feb 8, 2010 | 06:13 PM
trench555's Avatar
ya i found a marine gm motor chart and it says the motor is a standard rotation
and heres the cam number 14088526 is this okay
Old Feb 8, 2010 | 09:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by trench555
its a gm 350/5.7 stamped and all the info ive gotten is zz4 related and or truck related.
If it is new with those heads then it is L31 Vortec crate engine
1 pce seal crank ,Roller cam , might be 4 bolt mains
330Hp ?
Most likely have to swap out the marine flywheel that's all
Old Feb 9, 2010 | 04:30 AM
trench555's Avatar
330Hp ?
is there a special fuel pump i need to use all ive ever done on my old schools were mechanical and im thinking this motor will only take electric, and will this bolt up to my 350 trans any and all info is well appreciated.
id like to thank everybody for all your info thus far thank you
Old Feb 9, 2010 | 05:32 AM
trench555's Avatar
i found some info on what it is so here is the info/ will it work for my car
•Type: 90° 5.7L V8
•Displacement:350 cid(5736.50cc)
•Compression Ratio: 9.4:1
•Valve Configuration: Pushrod Actuated
•Valve Lifters: Hydraulic Roller
•Bore x Stroke: 4.00x
•3.48in(101.60x88.39mm)
•Main Bearing Caps: 2-Bolt Cast Iron
•Balance Method: External
•Horsepower:
•295hp@5000 rpm (PFI)
•Torque: 355 lb-ft@3600 rpm (PFI)
•Materials:
•Block: Cast Iron Intake Manifold: Customer Supplied
•Firing Order: 1-8-4-3-6-5-7-2
•Oil Pan Capacity: 5qt
•Fuel Types: Gasoline (unleaded)
•Engine Rotation: Clockwise (from the front)
•Paint Protection: Component Painted
This longblock is for GM Based Small V8 applications
including Mercruiser, Volvo Penta, Crusader, Indmar,
Marine Power, etc. There are various changes that were
made on the 5.7L engine throughout the years. Select
the following link that will assist you in choosing the
correct longblock for you application. Technical Tips.
This engine comes complete with all associated tin-ware
(oil pan, valve covers, timing cover), they do not include
the flywheel, balancer or water pump. These engines can easily
be identified by the (8) bolts used to fasten the intake
manifold to the cylinder heads.
NOTE: There is a provision for mechanical fuel pump on this engine. Therefore if you are currently using an electrical fuel pump you must get the fuel pump block off plate to cover this feature.
NOTE: It should be noted that the Vortec 5.7L longblocks are supplied WITHOUT a crank position sensor in the front timing chain cover. Therefore you must remove your existing crank position sensor and re-install it in the timing chain cover of the new longblock, otherwise the engine will leak oil out of this open hole. If your old engine did not utilize a crank position sensor you must purchase one to plug this hole as it requires this special o-ring type seal.
Old Feb 10, 2010 | 12:20 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
manifold to the cylinder heads. It should be noted that the Vortec 5.7L longblocks .
As I said above; it is a Vortec engine.
Nothing unique except the for the 8 bolt intake manifold.
Bellhousing the same as all SBC , any trans will bolt up .If you change the flywheel you will need a flywheel / flexplate to suit a 1 pce seal crank ('87+ F-Body ,truck , Vette ) as the older type will not bolt to your crank. You can replace the timing cover with one off any SBC so you don't have to plug the mentioned hole
Old Feb 10, 2010 | 06:24 PM
trench555's Avatar
thank you very much for your info. is there any good performance upgrades, as of now i have a new polished intake, and a new edelbrock 4brl carb. any suggestions on headers,fuel pump, ect.
Old Feb 10, 2010 | 06:54 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
It's a SBC; anything that works for other Chevys works for yours.Upgrade cam maybe?
jhawkeye
May 25, 2022 06:33 PM
slade5612
Aug 11, 2015 07:19 PM
anesthes
Aug 8, 2015 09:37 PM
1nastygta
Aug 8, 2015 07:38 PM
mustangman65_79
Aug 8, 2015 01:18 AM
