thoughts welcome
Old Feb 12, 2010 | 10:37 AM
RussC's Avatar
thoughts welcome
i'm looking at a set of rhs heads http://www.summitracing.com/parts/CCA-12317-01/ . will these work on my 89 tpi350? if so what would be a good cam to run? its a dd with weekends on the track.
Old Feb 12, 2010 | 07:36 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: thoughts welcome
They will use old style valve covers and likely old style intake bolt pattern. i recommend a roller cam to get the best performance.
Old Feb 12, 2010 | 10:11 PM
RussC's Avatar
how different is the bolt pattern? and is it hard to change it? would this motor already have roller lifters or would it be flat tappet? thanks
Old Feb 12, 2010 | 10:22 PM
im not sure if it would be roller. see what the engine rpo code is. the bolt holes in your stock heads are at a different angle. you would need to modify the intake
Old Feb 13, 2010 | 10:33 PM
RussC's Avatar
so to mod the intake would that just involve drilling new holes? or could i just reangle the current holes?
Old Feb 13, 2010 | 11:08 PM
the easiest thing to do would be to get a 85 corvette (they didn't make corvettes for one year, i dont think it was 85) lower intake. another problem i just remembered that i had was the intake ports in the head may be taller than your intake rendering everything useless. thats the problem i ran into and thats why my 84 has a carburetor on it instead of the tuneport. if you still want tune port it will be easier to go with L98 heads.
Old Feb 13, 2010 | 11:15 PM
ok they didn't make corvettes for 1983 model/year. just find out the intake port dimensions. they need to be about 2" tall. you can elongate those holes with a drimmel type tool. just make sure you have enough room for the head of the bolt.
Old Feb 14, 2010 | 05:15 PM
RussC's Avatar
what would be good L98 heads? afr's are way too expencive. i'm looking at around 900 shipped. would any of the dart heads be good? thanks
Old Feb 14, 2010 | 07:01 PM
just call rhs, or dart, or world or look on their websites and get the port dimensions. they cannot be taller than 2 inches. mock up the engine, if you can't get those bolt holes aligned, you'll need to get the lower intake. i had found some threads on porting the tune port intake, you'll need to do that to benefit from those heads. i highly recommend the dart iron heads.
Old Feb 14, 2010 | 07:39 PM
RussC's Avatar
thanks for your help, makes deciding a little easier
Old Feb 14, 2010 | 10:53 PM
GXR11's Avatar
Car: 91 C1500, 84 Camaro, 87 monteSS
Engine: 4.3L,Gen1 350. 391ci & 383 LS1
Transmission: t-5,man vavle body 700r4, no trans
Axle/Gears: 3:73, 3:42, 4:10
i have a set of the dart iron eagles (thier cast iron heads) and love them, i also would recomend these highly
Old Feb 14, 2010 | 11:29 PM
http://www.dartheads.com/products/cy...num-heads.html you can download the specs from here
Old Feb 14, 2010 | 11:47 PM
looks like the 10110010-10220010 will work. they even have enough meat for port matching. these heads are very heavy, but the good thing about that is you can port them as much as you want or angle mill. so as you make more and more power you can just keep porting the heads, really the last set of heads you'll ever have to buy. unlike a vortec head which is so thin porting wouldn't be a good idea.
Old Feb 15, 2010 | 06:55 AM
RussC's Avatar
thanks, that made my decision, i'm going with the darts
Elephantismo
Feb 13, 2019 12:51 AM
David Frans
Oct 31, 2015 08:12 PM
tmellott89
Oct 14, 2015 02:06 PM
Damon
Sep 26, 2015 04:29 PM
IROCZ1989
Sep 4, 2015 11:54 AM
