High quality RUBBER motor mounts and trans mount?
Old Feb 17, 2010 | 11:21 PM
87350IROC's Avatar
Car: 87' IROC
Does anybody know of a supplier of high quality RUBBER motor mounts and trans mounts? I currently have polyurethane on both and hate the added vibrations. I am trying to avoid autozone type parts as they are typically low quality. If I can't find anything I will just buy from the dealer.
I am not interested in discussing poly vs rubber vs solid.
Thanks.
Old Feb 17, 2010 | 11:42 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Re: High quality RUBBER motor mounts and trans mount?
I have wooden mounts in mine.
Old Feb 18, 2010 | 01:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
For rubber I'd probably get original AC Delco parts. Not necessarily from the dealer, though.
Old Feb 18, 2010 | 04:14 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Or even NAPA.
I too dislike Autozone and PepBoys.
Advance seems to sell decent parts as well.
Old Feb 18, 2010 | 09:04 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Im not helping with your question but I just have to say that you have a beautiful car. Very nice
do you have any other pics somewhere that I could see?
Old Feb 18, 2010 | 10:37 AM
87350IROC's Avatar
Car: 87' IROC
I'll at least have to go to the dealer to get the part number. I can't seem to find it anywhere.
3rdgenmaro, Thanks for the compliment. You have a nice collection of cars yourself. I do have a flickr account with some pics, mostly projects pics but there are some good ones here.
Old Feb 18, 2010 | 10:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Mount, Trans, (Chev) (1987) GM part # 17982257
Mount, Eng GM part # 14039405
JamesC
Old Feb 18, 2010 | 04:22 PM
87350IROC's Avatar
Car: 87' IROC
Thanks James,
But I can't seem to find those part numbers on GMPartsDirect or Google. Any ideas?
Old Feb 18, 2010 | 04:39 PM
Engine: 383 Stroker
Transmission: t-56
id say call your local chevy dealership, but they really never know what theyre talking about.
Old Feb 18, 2010 | 04:45 PM
Engine: 383 Stroker
Transmission: t-56
*double post my baddd*
Old Feb 18, 2010 | 06:03 PM
JamesC's Avatar
The numbers were from my Parts & Illustration Cat. CD. I'd check with your dealership (could be those numbers are discontinued).
JamesC
Old Feb 18, 2010 | 10:02 PM
87350IROC's Avatar
Car: 87' IROC
Well I went to the dealer today.
Here are the current part numbers.
Motor Mount: 22188497
Trans Mount: 17982949
The crazy part. The dealer wants $120 for each motor mount and $140 for the trans mount. Even GMPartsDirect wants $80 for each motor mount and $75 for the trans mount.
So I'm still looking for other options. Any ideas?
I'll go with NAPA if I don't hear anything else.
Old Feb 18, 2010 | 10:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Give those numbers to an AC Delco dealer.
Old Feb 19, 2010 | 03:27 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
can i have your poly mounts?
Old Feb 19, 2010 | 06:57 AM
JamesC's Avatar
The dealer wants...$140 for the trans mount.
There were several types of cross members and mounts. Sorry, I don't recall the year(s), but one of the latter was an expensive oil-filled contraption, IIRC, that was very expensive. See post #17 of the following link for a pic:
https://www.thirdgen.org/forums/hist...ss-member.html
If that's it, check the last post in the above link for more info.
JamesC
Old Feb 19, 2010 | 12:53 PM
87350IROC's Avatar
Car: 87' IROC
JamesC
How interesting. I figured they were all the simple solid rubber design. I've never seen that double cross-member before. My '87 350 A4 has the single crossmember. The oil-filled unit is very interesting. I bet it isolates vibrations better than the rubber. Might be worth a shot. It looks like from the picture in post #17 of that link, the oil filled unit should work with my single cross member right?
Also the parts guy at the dealer said he didn't have a part number for my motor mount or trans mount for my year/engine/trans. He did have a number for '88 and on. I told him they were all the same. Maybe I'm wrong. Maybe I'll try another dealer. Or check the part drawings.
Old Feb 19, 2010 | 03:55 PM
87350IROC's Avatar
Car: 87' IROC
I called AC Delco, they confirmed the part numbers I got from my dealer.
Old Mar 9, 2010 | 06:59 PM
87350IROC's Avatar
Car: 87' IROC
I ended up ordering from a dealer. They were $171 shipped for the motor mounts vs $200 as GMPartsDirect.
Old May 25, 2010 | 03:45 PM
87350IROC's Avatar
Car: 87' IROC
I just wanted to update. I got the new rubber mounts in last weekend. They lowered the engine back to the stock height vs the poly mounts. Much better now.
Old Oct 3, 2010 | 07:49 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Did those mounts come with the engine brackets also, or were they something other than the general rubber mounts? I just can't see any justification for a dealer to charge what you were charged.
Old Oct 3, 2010 | 08:35 PM
87350IROC's Avatar
Car: 87' IROC
They come with the clamshell that bolts to the k-member. I have no regrets. Its highly likely that these will last significantly longer than the normal made in china specials from autozone, ect. I don't mind paying for some piece of mind.
Old Oct 4, 2010 | 08:35 AM
Car: 87 IROC
Engine: 5.7 TPI
I guess you certainly can't put a price on piece of mind. Glad they are working out for you.
Old Oct 4, 2010 | 01:53 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Just out of curiosity, whats the difference between the factory vs. poly mounts (other than the obvious difference in material)? My old "rubber" ones where pretty much non-existant when I pulled them out for poly mounts, so there was nothing to compare. Is it a difference in design? Or, does the rubber deform more, allowing the motor height to lower?
I do have to admit that the height change is a nuisance with a stock hood.
Old Oct 4, 2010 | 02:10 PM
87350IROC's Avatar
Car: 87' IROC
The metal rod that the long motor mount bolt runs through is positioned differently on the rubber mount vs poly. I also suspect the sag of the rubber plays a part as well. Overall I estimate the difference is nearly 1". For instance my y-pipe used to actually make contact with the floor pan now there is a significant gap. Also, the UMI strut tower brace would not fit because it hit the runners. Now there is at least a 1/2" gap. Again this is comparing brand new poly vs brand new GM rubber.
Old Oct 4, 2010 | 07:56 PM
Pocket's Avatar
Car: 91 Trans Am
Poly is just stiffer so the weight of the drivetrain doesnt compress as much. Rubber vs poly should have the same dimensions compared side by side
You may want to look into whats causing your engine to vibrate so much, even solid mounts shouldnt chatter your teeth too bad
Old Oct 4, 2010 | 09:49 PM
87350IROC's Avatar
Car: 87' IROC
Sorry, that doesn't account for a 1" difference. Like I said the difference comes from a combination of the poly being stiffer and the fact that the pin hole in the poly mounts is located in the wrong spot.
As for the vibrations, they are caused by the mounts lifting the motor to the point where the y-pipe hits the floor pan. Also, I'm not talking about teeth chattering vibrations, merely more vibration than i prefer on a mostly street car.
But then again I'm a bit different than most here. Seems like most prefer to make their cars as uncomfortable as possible despite never taking them to a track. I prefer to have a car that drives well on the street yet can and does see track time. I see virtually no advantage to poly motor mounts on a car like mine. I bet they would be fine if they were designed to sit the engine at the correct height, but I've learned my lesson.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Linson
Aug 21, 2015 02:12 PM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
Elliswon
Aug 10, 2015 12:33 PM
