thumpr cams
Old Mar 6, 2010 | 08:32 PM
Vortec_Formy's Avatar
Car: 89 Formula/94 z28
Engine: Vortec 350/ LT1
Transmission: WC T-5/ 4l60e
Axle/Gears: torsion posi 3.23s/auburn posi323s
thumpr cams
Hey guys I wanted to get your opinions or experiences and thoughts on the comp cam selection of thumpr cams. Was considering running them in my vortec motor.
Old Apr 25, 2010 | 09:37 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: thumpr cams
Wondering this as well, I have a Vortec 357 and a T5.
Old Apr 30, 2010 | 11:10 AM
jackel200269's Avatar
Car: 92 camaro
Engine: lo3 v8
Axle/Gears: 10 bolt posi 4.10
Re: thumpr cams
I just put a 295h thumper cam in my bbf 472 the other day. Now i know this is not a sbc but I can tell you this cam is awesome. It has a very aggresive exhaust note which I love, spins to 7000 all day and still makes enough power in the lower rpm's to spin the hell out of some 38 inch boggers. Another pirk was It did not require any mods at all to run it.
Old Apr 30, 2010 | 11:42 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: thumpr cams
The baby Thumpr has just about the perfect amount of overlap for best mid-range torque from a Vortec-headed 383. Assuming the roller Thump'r, of course. Non-rollers have no place in strokers.
If you're not going that route, you'll be giving up low-end for the sake of a sound that most people will interpret as needing fixed. Too many people already hate our cars, why make it worse? You're not gonna impress the Mustang guys, nor the ricers. It's too little return on too much investment.
Old Apr 30, 2010 | 03:54 PM
Re: thumpr cams
So for my motor which will be stock except exhaust, intake and carb, a roller thumpr would be ok? I'm looking at making around 375hp at the motor. btw my motor is not a 383
Old Apr 30, 2010 | 06:46 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: thumpr cams
If you want the lopey idle, the Thumpr is great. If you want mid-range torque, I can spec you something better. Want proof? Go see my sticky in the swap section, I've even put real dyno results in there.
Old Apr 30, 2010 | 09:32 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: thumpr cams
Joe Sherman has used a few in some of his builds and was surprised at how well they performed. I was skeptical at first but apparently they are a very decent cam.
Old Apr 30, 2010 | 10:20 PM
Re: thumpr cams
What do you recommend then? I will have the necessary work done to the vortec heads to accomodate whatever cam I go with. What should I pick then to get the most power out of my setup?
He used the thumpr cams? were they roller?
Old May 1, 2010 | 08:34 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: thumpr cams
https://www.thirdgen.org/forums/engi...st-builds.html , post # 2.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
