Oil pan capacity question
Old Apr 5, 2010 | 07:08 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I need to purchase an oil pan for my motor build and was wondering if a 4 quart pan is the stock size (4qt in pan, 1qt in filter) or if a 5qt pan would be the stock size?
Old Apr 5, 2010 | 08:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Oil pan capacity question
Very few automotive filters hold 1 quart. 1/2 quart or less is more common.
A 5 quart oil change includes the oil that's in the filter. How much oil will you need with a 5 quart pan and filter? To the full mark on the dipstick.
I run a 7 quart pan, a 3 quart oil accumulator and a system 1 oil filter. The full mark on my dipstick as been adjusted to the oil level at the top of the baffle in the sump. An oil change for me is 8-1/2 quarts.
Old Apr 6, 2010 | 09:25 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
I think the stock size is 4ts, I use a PF1218 oil filter which holds a quart. I put 5qts in my '89 and 6 in my '87. The '87 has a chrome mr gasket pan.
Old Apr 7, 2010 | 12:20 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello 85Iroc-Z!!
For an oil change, I use 5 liters of oil in my stock 1987 IROC 305 TPI, Approx 4 liters in the oil pan, and approx 1 liter in the PF35 oil filter!!
I pour in the 4 liters into the engine, then top up the oil filter with as much of the last liter as possible, install the oil filter, and then start up the car to circulate the oil, then top up with any remaining oil from the last liter, oil level is then at the full mark!!!
5 liters lasts 3000 miles, doesn't use a drop!!!
P.S. The PF35 filter is the extended version of the stock PF25!! More filter = more filtration????
Old Apr 10, 2010 | 11:43 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
OK, so then the 4 qt pan is the same size as a stock pan then right?
Old Apr 10, 2010 | 11:48 PM
Hello 85Iroc-Z!!
4 qts in the pan, yes would be my answer!!
Are you getting this oil pan "from" something, or at a local auto parts store??
Old Apr 11, 2010 | 06:44 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I am buying it from summit racing.
Old Apr 11, 2010 | 06:18 PM
Hello 85Iroc-Z!!
The stock SBC oil pan capacity can vary between 4 - 6 quarts!! GM lists the following: Z-28 = 4 quarts, 5.7 Camaro/Caprice = 5 quarts, Corvette = 6 quarts!!
A 4 quart pan will be fine, as long as you don't have a fitment problem with the oil pick up tube!!
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
