putting AC back into a Camaro
Old May 5, 2010 | 04:48 PM
pre-mixed's Avatar
Car: 1986 Iroc-z
Axle/Gears: 3.73 limited slip
Hey guys so i just got a 1986 Iroc a few days ago and it has a 350 TPI swapped into it but the guy who put it in didn't put the AC back in. all the post i can find about Air Conditioning are how to take them out, but i like driving in comfort. anyways my question is where did the compressor sit? their is a space on the lower passenger side of the engine where something was mounted but not sure if it was AC or EGR pump. right under my alternator but i thought i found some pictures where a compressor was sitting where my alternator is. anyways any help would be appreciated i will try to go take some pictures of what i am talking about real soon and get them up. i hope this is the right form to post this in. sorry if its not.
Old May 5, 2010 | 05:13 PM
DeuceNC's Avatar
Re: putting AC back into a Camaro
Can't swear as to its location for yours, but my AC components are all on the passenger side of the motor. I'm pulling them out either today or tomorrow, because I've got my 4th Gen for a "comfortable" car...lol.
Old May 5, 2010 | 05:56 PM
pre-mixed's Avatar
Car: 1986 Iroc-z
so i took some pictures but i cant seem to upload them off my comp. but their is a place on the driver side and passenger side where you could mount something i am just not sure which one is for the AC i think it is most likely the passenger side under the alternator so that the lines from the condenser and canister wouldn't have to go across to the other side of the motor
Old May 5, 2010 | 06:13 PM
pre-mixed's Avatar
Car: 1986 Iroc-z
so here are the pictures i just took thanks for the help
Attached Thumbnails putting AC back into a Camaro-dscn0279.jpg   putting AC back into a Camaro-dscn0277.jpg   putting AC back into a Camaro-dscn0278.jpg
Old May 5, 2010 | 07:19 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Here is a before and after of mine. Mine is a 305 TBI, ac was on the pass side.
Attached Thumbnails putting AC back into a Camaro-01.jpg   putting AC back into a Camaro-02.jpg
Old May 5, 2010 | 07:50 PM
pre-mixed's Avatar
Car: 1986 Iroc-z
hey thanks ya your compressor is right where my alternator is. i will have to see about moving my alternator back over to the other side.
Old May 5, 2010 | 07:59 PM
Mikes86transam's Avatar
Car: 86 Trans AM LG4 5spd
On my 86 TA my AC compressor was on the drivers side. Looks like yours was also on the drivers side.
Old May 5, 2010 | 08:10 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Is yours TPI? If so then it is in the correct area. Make sure you still have the correct blower motor setup and it hasn't been replaced with a ac delete one. Compare your driver side firewall to my pass side to see if the hook ups are still there.
Old May 6, 2010 | 12:26 AM
pre-mixed's Avatar
Car: 1986 Iroc-z
hey thanks. I do have TPI and how will i tell if it has the correct blower motor? I was told that it got a new heater core and blower motor very recently. thanks for your help
db057
Aug 22, 2015 08:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
