Engine Missing! Whats wrong?
Old May 6, 2011 | 07:24 AM
  #101
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Re: Engine Missing! Whats wrong?
Originally Posted by jay173
That is a lot in labor man.
That's what I thought. I was thinking it would be more in the $100-$150 range, MAX. All in all I'm going to keep looking for different places to see what they charge (jiffy lube, jensen tire, etc).
Old May 6, 2011 | 08:01 AM
  #102
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I don't know what Jiffy Lube is like in your area. But here they are staffed by lube techs with absolutely no technical background. There is no way in the world I would ever let one of those hacks touch my car. While the labor quote from the dealer sounds high, the parts quote sounds low. Too low to include all the necessary parts. You need to replace plugs, wires, cap and rotor and inspect the distributor for visible signs of failure.
A secondary misfire will not cause code 42. This code is caused by an issue somewhere between the distributor and ECM. You either need to educate yourself to properly diagnose this system or find someone who can.
Old May 6, 2011 | 04:47 PM
  #103
jay173's Avatar
Maybe you can find a small shop that wont charge you as much.
Old May 6, 2011 | 04:58 PM
  #104
ahankins32984's Avatar
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
Originally Posted by Camaro305SB
Thats b/s don't spread crap like that around. If you had a bad experience, fine, but most dealership mechanics are just that - mechanics. Just like all the independent shops. Difference is - they (we) work at a dealer. The labor rate may be high but if your willing to actually pay it, you'll usually get good service. People complain about dealer mechanics, but never wanted to pay for diagnosis in the first place. Everyone wants everything fast, free, and flawless. Thats why the service industry is in the toilet to begin with.
/rant.
Well i happen to work for a dealership parts and service department and i never said that the mechanics were the bad thing about dealerships I'm talking they overcharge you for parts and labor so thank you so much!!! You can always find a better deal outside of a dealership
Old May 6, 2011 | 11:35 PM
  #105
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
What is sometimes hard to find outside the dealership is qualified mechanics. Our cars are getting old too and not many mechanics are familiar with them. I suggest you interview any shop you go to and see if they know your car.
Old May 6, 2011 | 11:37 PM
  #106
Engine: 5.0 305 TPI
i totally agree
Old May 31, 2011 | 09:44 PM
  #107
I got the Camaro running on all 8 cylinders again! I started to talk to my neighbor about what was wrong with the car (the same one that noticed the miss) and he said that he would give it a try based on all the estimates. So after a new set of plugs and a new set of wires it is running perfect. No more shaking at lights, loss of power, or bad hesitation. Just RAW untempered POWER!!! Thanks for all the suggestions everybody and for sticking with me through the entire process.
Old Jun 1, 2011 | 12:07 AM
  #108
jay173's Avatar
Now your gas mileage should improve!
Old Jun 1, 2011 | 12:15 AM
  #109
Too soon to tell, so far I have been keeping my foot into it!
Old Jun 1, 2011 | 12:38 AM
  #110
jay173's Avatar
That and more burn outs by accident
Old Jun 1, 2011 | 12:47 AM
  #111
Haha, yeah, I have finally been able to make the tires squeel instead of them just roasting!
Old Jun 2, 2011 | 12:12 AM
  #112
Update: Not only have I noticed increased throttle response but my car has a powere curve now when it used to just fall on its face on the first to second gear shift.
Question: You know the wire that runs from the distributer to the other component (rotor?) is it important to have that wire changed out too? If so where can I get it?
Old Jun 2, 2011 | 12:22 AM
  #113
jay173's Avatar
You mean the wire from center of the cap to the coil?
It should have came with spark plug wires but many times you can buy it seperate. Just pull it off to see its condition you dont have to as long as everythings working in harmony.
Jake_92RS
Jan 28, 2020 10:37 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
