Car smoles after comes back from shop
Old Sep 15, 2010 | 08:20 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Got my car back from the dealership after they did an oil filter change and oil change. Drove it all the way home and when I get in the driveway after I get out I do that 'look at your car just one more time' thing. I notice a sort of smoke spilling out from under the hood, so I open up the hood to figure out where it is coming from and it looks like it is from where the oil filter is. My mom is worried it is something serious but I think I remember hearing that its normal for your car to smoke after an oil change because it is burning off the old oil. Is that what is happening? Car has never smoked before so Im hoping someone else could agree with me or atleast shed some light.
Old Sep 15, 2010 | 08:44 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Car smoles after comes back from shop
Whoever changed your oil, spilled some on the block or exhaust manifold causing the smoke. You can take some water and rinse it off. Or it will smoke off in a short time.
Old Sep 15, 2010 | 11:18 PM
I bet they did it on purpose because the last time I was there they took 3 and a half hours to just change the oil. So my mom (Im 16) complained about it and so the guy said we will give you a free oil change. It is a Lincoln dealership so I guess they take complaints really bad.
Old Sep 16, 2010 | 07:01 AM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
yeah they spilled oil on something . Do yourself a favor spend 30$ on some ramps 10$ on a drain pan and 2$ on a funnel it'll save you a ton of time and money , dealerships rob you on that kinda stuff.
Old Sep 16, 2010 | 05:13 PM
red rock's Avatar
Car: 1987 iroc
Never take a chevy to a ford/lincoln dealer for anything! That's blasphemy. You can take a ford to a chevy dealership, but not the other way around. Just kidding, if they do that sloppy of a job, i would try to do it yourself or look elsewhere.
Old Sep 16, 2010 | 07:02 PM
Yeah I would take it to a chevy woodhouse dealership except the closest one is over 40 miles away! Woodhouse normally has very good quality work. I would do it myself but parents are divorced and I live with mommy who can name every car she sees but doesnt know much about repairs. If I did live my dad he has no idea how to either, so I guess I will ask a friend how to or something.
Old Sep 16, 2010 | 07:12 PM
red rock's Avatar
Car: 1987 iroc
Man, good luck, If i were closer i would help, and show you how to take care of the basics. Don't be afraid to ask questions, that's how we all learn.
Old Sep 17, 2010 | 02:04 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Its very simple....
1. Warm up engine
2. Turn off engine
3. Remove drain plug and let oil drain into pan
4. Remove oil filter and let oil drain into pan
5. Replace drain plug
6. Install new oil filter, put oil on the rubber gasket on the sealing surface of the filter and on the inner threads of the filter (to prevent leaks and prevent seizing respectively, not a big deal to do it perfectly)
7. Put 5 quarts in the top of the engine.
Old Sep 17, 2010 | 05:18 PM
red rock's Avatar
Car: 1987 iroc
Originally Posted by InfernalVortex
Its very simple....
1. Warm up engine
2. Turn off engine
Yes it is simple, for someone that's done it a thousand times. But we all had to be taught at one time or another, or there wouldn't be no experts.
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZ1989
Jan 24, 2016 03:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
kah992
Aug 19, 2015 02:55 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
