timing chain
Old Oct 13, 2010 | 06:37 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
timing chain
i have a 79 350 i need a timing chain set. there are so many what is one i wanna go with?
Old Oct 13, 2010 | 06:57 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: timing chain
something like this
http://www.jegs.com/i/Cloyes/220/9-1100/10002/-1
or whatever you can get at autozone.
Old Oct 13, 2010 | 06:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: timing chain
Comp Cams 2100 would be fine, or the 3100 if you want a little better true roller.
Old Oct 13, 2010 | 07:19 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: timing chain
Originally Posted by RED86Z28
something like this
will probably go with that one. But my crank sprocket is really stuck on there is there a special way for it to come off? And what causes crankwalk and how is it fixed?
Old Oct 13, 2010 | 07:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: timing chain
The crank sprocket is pressed on, you'll need a puller to take it off. Crank walk is caused by a worn-out thrust bearing.
Old Oct 13, 2010 | 07:47 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: timing chain
where is the thrust bearing at? is it just behind the crank sprocket? its a 1979 sbc 350 btw.
Old Oct 13, 2010 | 08:04 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: timing chain
Its been a while since I took my block apart but the thrust bearing is the rear bearing. If it needs replacement you have to change all the main bearings.
Old Oct 13, 2010 | 08:07 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: timing chain
well im pretty sure it needs changed and the motor is in the car am i able to change them in the car?
Old Oct 13, 2010 | 08:11 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: timing chain
do you also need a special tool to install the crank sprocket?
Old Oct 13, 2010 | 10:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: timing chain
Trying to change a bearing in the car would be far more trouble than it's worth. Better to pull the engine, so you can do it properly. Why do you think the crank is walking anyway? Have you measured the endplay?
There are tools to install the crank sprocket, or you can heat the sprocket and slip it on with a little juidicious tapping from a non-marring hammer.
Old Oct 14, 2010 | 06:50 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: timing chain
oh the crank moves back and forth about a 1/4 inch and i never noticed it till setting the timing when it reved up the crank moves forward.
Old Oct 14, 2010 | 09:20 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: timing chain
Time for a rebuild then.
Old Oct 14, 2010 | 08:16 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: timing chain
this motor is supposed to have only 30k on it you think i can get away with just bearings? All cylidners have 130-150 psi cold
Old Oct 14, 2010 | 08:44 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: timing chain
The only way to do this right is to take it apart. No engine with 30k on it should need bearings replace. If everything looks good clean it out an reassemble it with fresh bearings.
Old Oct 14, 2010 | 09:05 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: timing chain
is the thrust bearing gonna be included with the main bearings and where is it really located at?
Old Oct 14, 2010 | 09:17 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: timing chain
The crank bearing set will include the thrust bearing. Its the one in the back.
Old Oct 15, 2010 | 02:29 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: timing chain
There is no thrust bearing, per se. The #5 main bearing has thrust faces on it.
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
