Wont run timed @ 6 BTC
Old Nov 14, 2010 | 03:02 PM
Rick87IROCZ's Avatar
When I retard the timing it will run and almost idle but when i put the timing at 6BTC it wont rev or stay running
any ideas?
Old Nov 14, 2010 | 03:05 PM
SoCo80p's Avatar
Re: Wont run timed @ 6 BTC
Are you using an adjustable timing light? If so, is it set to 0?
Old Nov 14, 2010 | 03:12 PM
No timing light is not adjustable
Old Nov 14, 2010 | 03:18 PM
Guest
Guest
Posts: n/a
Did you disconnect the tan wire?
Old Nov 14, 2010 | 03:39 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
there is a tan wire with a black trace/line that must be dis-connected to set timing . called EST , electronic spark timing . it's located near the heater box , mine is between htr. box & A/C plumbing . there is 2 1/2" connector , dis-connect , set timing (mine is set at 0) , re-connect . should be good to go , good luck .
Old Nov 14, 2010 | 03:44 PM
[quote=UNCLE TOM;4734861]there is a tan wire with a black trace/line that must be dis-connected to set timing . called EST , electronic spark timing . it's located near the heater box , mine is between htr. box & A/C plumbing . there is 2 1/2" connector , dis-connect , set timing (mine is set at 0) , re-connect . should be good to go , good luck .[/quote
I had EST wire disconnected
mine times at 6BTC
its a 1987 5.7 Iroc Z
ive checked for vacuum leaks replaced the coil MAF cap rotor wires (yes ive checked firing order a dozen times) TPS is set at .55
Old Nov 14, 2010 | 05:01 PM
OK im back to 6 BTC base running like crap and wont idle or stay running.
anybody have a hand grenade?
Old Nov 14, 2010 | 05:42 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Wondering if your balancer may have spun and is not giving a true reading.
Old Nov 14, 2010 | 06:08 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Do you have a stock timing tab, or a adjustable tab? Awhile back my adjustable timing tab moved caused I didn't tighten it down well. Which made me think my timing was some where else. I had to use a piston stop and find TDC for number one. I then re-adjusted my tab to the correct position, and all was well afterwards.
Old Nov 14, 2010 | 06:14 PM
Lemme guess:
Stock balancer, replacement timing cover with bolt-on aftermarket timing tab; probably "chrome" :barf: ?
That combination puts the timing mark roughly 35° retarded from where it's supposed to be. Meaning, when you follow the "procedure" and "set" your timing, it will be approximately 29° ATDC (retarded), instead of 6° BTDC (advanced).
Best thing to do would be to locate #1 TDC by some ACCURATE means, totally independent of the timing mark, such as with a piston stop; make a new mark on your crank damper that lines up with 0° on whatever tab you have; and then you can use a light.
Or, you can just set it to where the car runs the best, and not bother with a light at all. Since after all, the engine doesn't whup out a light and look at the mark and decide how it's going to run; it merely responds to how the thing is put together. It doesn't need to see the mark to know what to do, you don't really either.
Old Nov 14, 2010 | 08:04 PM
Lemme guess:
Stock cover new stock balancer when rebuilt about a year ago
Old Nov 14, 2010 | 11:20 PM
Guest
Guest
Posts: n/a
Verify TDC. There is more than one balancer and timing tab location depending on the application. You may have a mismatch, or your new balancer may have become old real quick.
Old Nov 15, 2010 | 06:07 AM
Find TDC with a piston stop and verify your timing marks.
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
