fouled plug
Old Mar 5, 2011 | 10:49 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
fouled plug
I just pulled my plugs today and all looked good accept for #2. It's fouled, just nor sure if it's fuel fouled or oil fouled???..I can't tell from the smell. I just had all my valve guides replaced 160 miles ago and if they are going again i'm going to puke!
Old Mar 6, 2011 | 12:51 AM
Car: 89 Formula 350
Re: fouled plug
just wondering if it looks more like fuel or oil?????...one side of the plug looks like a dull black the other side has more of a rough shiny black????
Old Mar 6, 2011 | 03:11 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: fouled plug
Oil deposits are white and chaulky. Very rich fuel mixture is black and sooty. This looks like unburned fuel deposits from no or weak ignition. Though it may just be running a bit rich. Was it wet when it came out? Have you noticed a misfire?
You run the superram TPI don't you? You could have a bad ignition wire or a bad injector. Verify compression on that hole.
Old Mar 6, 2011 | 10:40 AM
Car: 89 Formula 350
Re: fouled plug
When I had all my guides go bad last time I did have white deposits on the plugs. I havent seen that on this plug yet. As of now it looks like a dry black soot on one side of the insulator and a wet/more shiny black on the other half of the insulator. At idle the engine surges like 200 RPMs in park. I had a tune I was running for the past 150 miles that sounded like it was detonating over 4300 RPMs at WOT, engine is 11:1 with 93 octane. That tune had 34* total timing and was around 12.5-13.2 WOT, 14.5-15.2 driving normal. I now have a tune with 29* total timing with 5% more fuel added and I dont hear detionation at WOT anymore. Both tunes A/F mixtures look good while driving and WOT but the WB O2 gauge at idle moves between lean and alittle rich as the car surges at idle. I put the car on a smoke machine, showed no vacuum leaks..TPS,IAC,fuel pressure,all good. So far its just the one plug looking bad. I did a resistance test on all my wires and they are good. the ignition is stock bedides for an msd blaster coil..Maybe i need to step up to a 6AL? I also did an OHMS test on all my injectors, all 14 ohms cold and between 15-16 warm. I just checked compression on that cylinder with the other plugs still in...180psi. No blue or black smoke from the exaust yet. I'm really hoping its a fuel problem not the valve guides going bad due to the few pulls I made with detonation??? Geomerty is perfect I check a few times.
Old Mar 6, 2011 | 11:41 AM
Car: 89 Formula 350
Re: fouled plug
if I'm lucky and it turns out to be fuel over oil whats the fix...I see this fouling on #2 as in the pictures a also did see and very little of the same on #1.. Could this be because those are the longest spark plug wires. At what point does someone need a 6AL box?
Old Mar 6, 2011 | 02:01 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: fouled plug
That appears to be carbon,if it's just the one plug check the wire for corrosion or cracks,and the dist.cap at that wire make sure that doesn't have a crack in it.
Old Mar 7, 2011 | 12:45 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: fouled plug
The MSD is a definite plus on any highly modified engine. I would say you certainly qualify.
Old Mar 7, 2011 | 01:13 AM
complete loser's Avatar
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
Re: fouled plug
Looks like fuel to me to. If it fouled with oil, you would def know it. Burnt oil deposits can be white and chaulky. But unburn oil on a fouled plug is black and oilly. Especially down inside the plug.
If this is the only plug being goofy.
Check resistance on that plug wired compared to the others. Swap that plug with another. And or swap that wire with #1.
If its more than one plug, and you had a history of fouling before having the guides fixed, do this.
http://www.youtube.com/watch?v=vRAV5...eature=related
Then pull all the plugs and clean them well.
Old Mar 10, 2011 | 04:23 PM
Car: 89 Formula 350
Re: fouled plug
ok, figured it out...valve stem seal on the intake valve of #1 fell off.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
