Hit a bump and idle increases alot (HELP!)
Old Mar 7, 2011 | 05:23 PM
Danus's Avatar
Car: 1989 305 RS Camaro
Hi,
I'm having this nightmare problem, my cars a 1989 rs, 305 tbi auto. When I hit a bump in the road the idle increases hell of alot, service soon light comes on and the auto box will come out of overdrive
I'm in England and the people dont seem to have a code tester either. So was wondering if anyone came across this, or have any suggestions for things to look at?
any help much appreciated,
Dane
Old Mar 7, 2011 | 06:35 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: Hit a bump and idle increases alot (HELP!)
Does the idle go back down afterwards?
Old Mar 7, 2011 | 06:52 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Here's my guess: Broken brake booster hose flexes as engine compartment warms up and reveals crack when you drive over a bump causing a vacuum leak.
Old Mar 7, 2011 | 06:53 PM
Danus's Avatar
after a couple of minutes it will go back to running smooth, or turning the car off and on again
Old Mar 7, 2011 | 07:09 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
go out and run the car while wiggling wires and hoses in the engine compartment.
Hopefully the problem will rear it's ugly head for you....
Old Mar 7, 2011 | 08:52 PM
86_TA's Avatar
Car: 86 TRANS AM
Transmission: 700 R4
Axle/Gears: 3:73
I had a bad computer once. I could tap on it while the engine was running and the idle would change.
Old Mar 8, 2011 | 08:23 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Start wiggling everything on the harness and spray the engine bay with ether. Ether will find any vacuum leaks. If you lose vacuum anywhere near the booster it will try to create vacuum on it's own by hiking up the RPMs.
Old Mar 8, 2011 | 01:59 PM
Danus's Avatar
Sorry, whats ether? never heard of it?
evilstuie
Feb 28, 2016 03:33 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
gta power
Aug 13, 2015 06:15 AM
92camaroJoe
Aug 13, 2015 06:07 AM
