New cam..stock push rods?
Car: 88 iroc z28
Engine: Sbc 350
Transmission: 700r4 auto
Axle/Gears: ??????
I have a new cam to install and I'm wondering if I can use my stock push rods.
Cam specs are com cam cl12-242-2 or cs xe268h. I don't know how to find out myself so any help would be so much appreciated. Thank-you
Sb 350
Camel humps 291's
E brock performer intake
Flat top pistons (standard bore)
Qjet carb
Comp cam (above is numbers)
Sb 350
Camel humps 291's
Qjet carb
Car: 88 iroc z28
Engine: Sbc 350
Axle/Gears: ??????
Re: New cam..stock push rods?
As far as I know its 481 lift and 280 dur.
Car: 88 iroc z28
Engine: Sbc 350
Axle/Gears: ??????
Ok so I went to comp cam and put in my specs and couldn't figure out anything.... ahhhhh!!
So I promise I'm not just being lazy..I tried to figure it out on my own but with no luck.
Received 1,679 Likes
They should "work"; whether they're the "ideal" length, is another matter, as is, whether it's a "good idea" (since as we all know, just because a thing can be done, does not automatically promote it to a good idea). They are as weak as 3-hr-old spaghetti.
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Why not buy the recomended set of rods offered by comp? They dont cost that much and you'll have peace of mind knowing you've got the correct pieces that are new. Hope your going with a new set of lifters also
Car: 88 iroc z28
Engine: Sbc 350
Axle/Gears: ??????
Yes I am using new liters...I bought the cam from someone still in the box but did not get it from comp myself so I don't know what they recommend. Thank-you
Car: 88 iroc z28
Engine: Sbc 350
Axle/Gears: ??????
Weak spaghetti because their old? Thanks
Weak spagetti because they're made from crap material and are thin. Good push rods are made from chrome moly steel.
Car: 88 iroc z28
Engine: Sbc 350
Axle/Gears: ??????
LT1Formula
10-08-2015 08:34 PM
skinny z
10-05-2015 06:23 PM
