89 camaro rs OBD plug?
Old Apr 24, 2011 | 07:52 PM
Ttopsupreme's Avatar
Car: 89 camaro rs coupe
Engine: 89 305 tbi ohv 5.0
Axle/Gears: normal
Hey guys i need some help, this ir my first 3rd gen and i have an 89 camaro rs with a 305.
i just got the car a while back and its in the shop because i need to replace the heads and gaskets. After i got it i tuned it up ( sparkplugs, wires, dist. cap and rotar, fuel filter, oil filter, oil change, and air cleaner) and most of my dash lights went away after i did the break shoes, cylinders, convoy kit and such.
Now i need to find the OBD plug or something for a scanner. The autoparts store will scan it for free if i can find where the plug is for the GM scanner but i have had no luck looking online. MY dad says its probably under the drivers side dash but the Guy at the store said it would be somewhere else for vehicles older than 96.
Im only 17 so sorry if there is any typos, but i would appreciate the help if someone could direct me towards the inlet.
-thank you
Old Apr 24, 2011 | 08:17 PM
Re: 89 camaro rs OBD plug?
You don't need a scanner for one of these cars. All you need is a paper clip.
https://www.thirdgen.org/service-eng...ht-error-codes
Old Apr 24, 2011 | 09:11 PM
Axle/Gears: normal
okay all i need is a paperclip but i still need to know where the plug thing or whatever is located to put a paperclip/scanner on?
Old Apr 24, 2011 | 09:33 PM
Right above your right knee.
Old Apr 26, 2011 | 07:07 AM
torque_is_good's Avatar
what's a convoy kit?
Old Apr 26, 2011 | 07:30 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I think he means combo kit, brake hardware.
While the paperclip method works for reading codes, an actual OBD1 compliant scan tool is still of great value in diagnosing an OBD1 vehicle. It's possible that an AZ store has a generic scan tool that will read GM OBD1 with the right interface, though not likely. Im afraid the counter person you spoke to probably just doesn't know the difference.
Old May 14, 2011 | 02:02 PM
Axle/Gears: normal
okay ill look for it after i get my car back thank you. yes convoy kit is break hardware like adjuster and springs, e clips for holding the parking break cable onto the shoe and such. Oreillys said they could use their standard GM scanner on my car if i found the OBD plug but they didnt know where it was so thank you. My dad just told me it wasnt in the dash on older cars so i had no idea. also im having cooling problems if any of you are knowledgable in that field?
Old May 14, 2011 | 02:12 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
It is right beside the fuse box on the drivers side. Small black box with 12 pin holes. It is called the ALDL.
rocn7roc
Sep 21, 2021 02:16 PM
Derick15
Sep 17, 2016 05:28 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
