should I buy a block without main caps?
Old Apr 30, 2011 | 09:44 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
I've been wanting to build a 383 and found an 3970010 casting 4 bolt main bare block, .10 over now and owner says should clean up with a hone only for $50. But he doesn't have the main caps for it. From what I have read those aren't something I can just get from another block and bolt on. Is this right and what kind of extra machining costs would I be looking at to make some others work if it is needed. Would I be better off finding a block with caps and spending $100 on it or pick this one up for $50.
Old Apr 30, 2011 | 09:54 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: should I buy a block without main caps?
I'd pass and keep searching.
Why wouldn't dude have the caps?
Old Apr 30, 2011 | 10:05 PM
chevysquid's Avatar
Think I will hold out. Still kicking around the idea of a SBC 400 also. I have everything I need to do a head/cam swap already (vortec heads w/ comp cam XE 268H-10).
Old Apr 30, 2011 | 11:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Pass unless the block is free. Buying new caps and having the block line honed would be an added expense that you don't need.
Old May 1, 2011 | 12:46 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
pass on it. Why do you want an non-roller block for your camaro?
Old May 1, 2011 | 10:51 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Any block can have a roller cam. The older blocks just don't have a keyway for OEM style lifter alignment. You just need to use lifters with link bars in the older blocks.
Old May 1, 2011 | 10:57 AM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Good to know! Whats up Alky!
Old May 1, 2011 | 08:28 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
True. But if you are looking for a 350 block, why choose a early block (up to 1979) when 87-up blocks all have OE roller cam provisions, rather than paying $500 for the roller link lifters?
Infested
May 22, 2018 11:56 PM
lakeffect2
Aug 23, 2015 08:44 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
