Looking to buy a new A/C selector mode switch- but from where?
Old Aug 17, 2011 | 11:56 AM
damage31's Avatar
I've known for years that my cars A/C control was leaking vacuum, but I never bothered to replace the a/c selector mode switch, as it always worked sooner or later.
Well, now its finally given up the ghost and I'm stuck on the defrost.
So I searched this site, and read up on what I need. However- when calling around for parts from local suppliers (napa, o['rielly, autozone, GM dealer)
What I'm looking for cant be found in stock anywhere in the world. Four Seasons, Murray, Everco-- all out of stock everywhere.
I'm looking for the GM part # 16032395 Which is also known as/looks like one of These
I'd really like to buy a new one, rather than a junkyard part, as I haveno plans to sell my car....ever. I'd even buy an all new heater control unit if needed...but also cant find one of those either.
Anyone have any thoughts where I might be able to go to get a new a/c selector mode switch, or an entire a/c heater control unit?
Old Aug 17, 2011 | 12:02 PM
torque_is_good's Avatar
Re: Looking to buy a new A/C selector mode switch- but from where?
are you sure that the vacuum hose under the hood isn't disconnected or cracked?
Old Aug 17, 2011 | 02:30 PM
damage31's Avatar
No leaks under the hood.
You can hear the hissing right at the back of the control while inside the car. I just like things to work the way they are supposed to work.
Whats disappointing is that no one has these in stock in the aftermarket. Their like hens teeth from what I am finding...
I try to take care of the car. I've owned it since ~1994. Its still in nice shape as far as i'm concerned. Not perfect by any means, but normal wear and tear is starting to show in the common places- Drivers seat is starting to tear on the bolsters from getting in and out, the drivers seat belt plastic is broken.
I just now (today) had to replace the original alternator as it finally gave up the ghost last night coming home from work.
Other recent repairs this year have been tires/shocks/struts/transmission mount/idler pulley/heater control valve, as well as all fluids. I did carpet and a new top a couple years back.
Old Aug 17, 2011 | 06:17 PM
Yeah AFAIK you're not going to find that new anywhere but GM; and that's not bloody likely.
Fortunately ALOT of vehicles use the same one. Shouldn't be too hard to come up with something at yer local buzzard.
They're not hard to take apart, lube with silicone grease ("dielectric" grease works fine, and run for another few decades. In fact that might be all your existing one needs. Take a look.
Old Aug 17, 2011 | 08:56 PM
damage31's Avatar
I might try the grease, since I'm probably stuck with a junk yard part.
I'll probably get around to it in a week or so- so far, it looks like the weather will be nice for the next week or so which will allow me to put the top down and skip the A/C.
Old Aug 17, 2011 | 11:16 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
You mean this -
https://pontiworld.com.au/usgmsp/pro...oducts_id=5246
This is a local supplier over here, he ships worldwide afaik.
Old Aug 21, 2011 | 10:24 PM
damage31's Avatar
I'll try to contact them in a week or so, after I've had time to tear my car apart and get at the part to confirm the bad switch.
If they've got it, im buying it. For whatever reason I cant seem to find them in the US.. not sure why.
Old Apr 10, 2016 | 10:46 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I was alerted to the need for this item by a customer. I have some of the GM 16032395 that I have refurbished and tested in stock. I came upon this old thread and thought I'd let everyone know.
http://www.top-downsolutions.com/ind...category_id=67
Lon Salgren
Old Apr 13, 2016 | 01:41 AM
lonsal's Avatar
As promised, the trifecta of switches and valves that are part of the HVAC system are now available from TDS:
GM 16062091: HEATER WATER CONTROL VALVE
GM 16032395: A/C HEATER MODE CONTROL VALVE
GM 16014416: A/C HEATER MODE SELECTOR SWITCH
Lon Salgren
Old Jul 26, 2016 | 03:44 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
I just bought one of these last week, GM 16032395 from TDS. They describe them as "refurbished", but they look and operate as new. It also came with new screws, and the two small, round retainers that fit onto the pins to retain the vacuum lines to the control panel. I finally have a leak-free A/C control panel!
Old Apr 10, 2025 | 04:49 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I need one again
Old Apr 10, 2025 | 09:19 PM
BURD's Avatar
There’s one on eBay
Old Apr 10, 2025 | 10:31 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
I don't know if this can help you or not.
North Carolina Firebird Heater Control Panel $25 - Third Generation F-Body Message Boards
Old Apr 10, 2025 | 11:17 PM
KITT1983's Avatar
Old Apr 11, 2025 | 12:45 PM
KITT1983's Avatar
Originally Posted by Airwolfe
Old Apr 12, 2025 | 08:20 AM
BURD's Avatar
When did that change, I have the square version of that, camaro is diff that Firebird, bought it by mistake.
OldCelica
May 21, 2018 08:45 AM
larsulrik
Mar 17, 2014 09:34 PM
Red92Bird
Aug 24, 2007 01:08 AM
techno101
Jan 23, 2007 07:07 PM
gloin85
Jul 31, 2003 03:04 PM
