no FP fuse?
Old Aug 18, 2011 | 02:36 PM
coreys90iroc's Avatar
Car: 90 Iroc
Transmission: 700r4 Built by- Speed Secrets
no FP fuse?
im trying to replace my fuel filter and im trrying to find my pump fuse, i looked under the dash and there is not a FP fuse! how do i relieve the pressure when im supossed to take out an non existant fuse to do so?
Old Aug 18, 2011 | 03:55 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Re: no FP fuse?
as long as the ignition is off there should be no juice to the fuel pump. i think removing the fuse is a precautionary measure. i believe the fuse is an inline in its own fuse holder next to or right around the battery. the wire its on should be orange.
Old Aug 18, 2011 | 04:16 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: no FP fuse?
Just replace the fuel filter.
I've done it many times with no preliminary precautions other than making sure the car is safely supported on jack stands, and keep fuel out of your eyes. lol
Old Aug 18, 2011 | 04:32 PM
Car: 90 Iroc
Re: no FP fuse?
i tried to and it just comes out way too much and wont stop. its a TPI not carb
Car: 90 Iroc
Re: no FP fuse?
and there is no fuse near the battery either
Old Aug 18, 2011 | 04:42 PM
Re: no FP fuse?
Plug it with your finger and install it quickly. I have done it many times and fuel spilling is unavoidable. The fuel is coming out from suction/gravity, not because the fuel pump is pumping it out.
Just be quick about it and you'll be fine.
There should be a fuse by the battery in its own plastic casing screwed to the inner frame rail. It is the ECM fuse, and unplugging it before replacing a fuel filter will make zero difference in the fuel spillage.
Old Aug 18, 2011 | 04:48 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: no FP fuse?
Yes there is. Its under the hood on the pass side infront of the wheel and close to where the fender bolts on..
on firebirds its on the dr side between the bat an the rad..
Old Aug 18, 2011 | 08:49 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: no FP fuse?
If this is a TPI car - there is a shraeder valve on the fuel rail - cover it with a rag, and depress the inner button (like a tire stem) with a screwdriver - this relieves the pressure and thus none will leak out when replacing fuel filter.
Old Aug 18, 2011 | 09:14 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
Re: no FP fuse?
the reason he wanted to find a fuse is so he could pull the fuse, start the car and let it "run out of gas" and then replace the fuel filter. the guy saying "the fuel pump is off When the key is"...well no ****...that's not the problem. but yes, using the schraeder valve will work too, it'll just take a while...
oh, And BTW, you can pull the fuel pump relay...that will effectively kill the fuel pump.
The fuel pump relay is located on the
firewall ,if your looking at it from the
front of the car it will be the furthest
relay to the right it will have five wires
going into the connector.
Old Aug 18, 2011 | 09:23 PM
Pocket's Avatar
Car: 91 Trans Am
Re: no FP fuse?
Using the schrader valve will relive the pressure so when he cracks the line open he doesnt get a face full of gas. It does nothing to stop the siphoning effect
Just plug it with your finger and be quick. With stock hardlines, that was my least favorite of all the annual maintenance
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
