please help, my car is starting to miss pretty bad
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
for some reason lately my car is starting too act up and spudder and pop out the exhaust and lose power at normal driving speeds and sometimes under full throttle, people keep telling me that it might be the icm or something in my ignition.ive checked for burnt plug wires and bad plugs even though im running the E3 platinums, is there anyway too check this out and is there any other things that can cause this that i can check?any ideas would be very helpfull because i am stumped, thanks
Re: please help, my car is starting to miss pretty bad
just because a plug wire "looks OK" does not mean it is OK
8 new plugs, $20 ( you don't need expensive ones)
set of new wires $30
new rotor and cap- $10
new fuel filter- $9
timing- free because you already own the timing light don't you?
new O2 sensor- $25
new fuel filter- $9
new O2 sensor- $25
everything u just listed is pretty new and only only have 800miles on them, the problom only seems too happen after it warms up??
how do you know for sure that all the things I listed have been replaced?
Or, were they simply "checked"?
you must rule out the basics before going after things which are enabled in closed loop. Yes, I know the O2 works in closed loop
i was the one who replaced the parts listed above i never let anyone else touch mt car, so i hope that the parts didnt fail already
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
i would change the plugs first ive heard of them not working well for some poeple search on here you will find a few threads on those plugs
i changed the plugs and there is still no difference
Engine: 4++,350 & 305 CIs
Check the Inj ohms an make sure they are all the same ish.
also pop the hood with the engine running at night in a very dark place. Use a squirt bottle and mist/spray the plug wires. if they are bad you will see them arc..
Also check 4 vac leaks with carb an choke cleaner around your intake gaskets.
should i check the injectors while the engine is hot or cold? also it seems too run fine until it hits close too opperating temp and then has the miss/poping noise and loses power, can ijectors work fine and then quit workin when the motor warms up?
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Both. Yes, that's why you check resistance cold & hot.Then do an injector balance test.
ok i checked them and cold they are 15.2 ohm and running temp they are at 16.2, is this normal?? and how do i do an injector balance test?
db057
Aug 11, 2015 10:11 PM
