cam retainer issue
Old Nov 16, 2011 | 09:15 PM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
cam retainer issue
i came to a stump while doing my build earlier today. i was tightning my reatainer bolts tighten it a lil to much and it broke (got the kit to get it out but back to topic) so i went to napa and found a hex bolt though it on and height clearence was good. so i turned the cam ith the gear and heard a scraping noise on my duralast timing chain from autozone prt number 78150.
so i took it off and notice the corner hitting the timing chain so with this being said i took one of the olds retainer bolts and notice the same thing with this one!
but it being round is it susspose it just tuns on it but then i realized its a bolt with threads.
so i took out the caliper and measure the back side of the cam gear that the ratainer hits and the duralast one is slightly bigger then the stock.
so is this normal i kno i should not replace my cam retainer possibly need to replace the timing chain set
any help would be nice
and seeing how the bolt i need fromm summit is seven bucks shipped probably a junkyard trip for this bolt
any help would be awesome
blocking my build
Old Nov 16, 2011 | 10:31 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: cam retainer issue
What extent is the rebuild-
Complete with parts from a kit or just freshening with new rings & bearings?
Can you post pics of the problems?
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Kinda hard to follow you, But if the cam gear is rubbing on the correct size bolt head even though the autozone 78150 is suppose to be right and converts to a cloyes 9-1145 .
Old Nov 16, 2011 | 11:01 PM
dabird07's Avatar
Car: 92 firebird
i geuss all my threads are hard to follow cause i dont use the correct terms idk maybe i should work on my english
and ill have to get pics up tomorrow
i might be over looking when i originally had the retainer and gear on and turned it to match top dead center it didnt make a scraping noise
i geuss this is how is suppose to be with the side of the retainer bolts hittin the side of the timin gear???
well not side of the gear where chaiin goes damn pics ould help h/o
Old Nov 16, 2011 | 11:28 PM
dabird07's Avatar
Car: 92 firebird
Old Nov 17, 2011 | 09:51 AM
dabird07's Avatar
Car: 92 firebird
i hope the picture helps
Old Nov 17, 2011 | 10:04 AM
Engine: Lb9
Transmission: M20
I would use the right bolts gm 14093637 and put some loctite 242 on the threads. Than check your car gear clearance it it rubs than that timing set will not work. don't use a tapered head bolt here there is no surface area for it to tighten against the plate. A bolt like that would be used in something that is counter sunk. Actually your picture is blurry so I cant tell if this is the right gm bolt !!
Old Nov 17, 2011 | 08:34 PM
dabird07's Avatar
Car: 92 firebird
that one is the gm bolt the other bolt is in the block ell half of it . .. i was just wondering if any one else had this propblem
going to look for some others i got the crank gear on it the same as the duraklast i wonder if a different timing gear will work with the duralast crank sprocket or wateva its called
Street Lethal
Apr 30, 2019 12:14 PM
Cameeeero
Sep 18, 2015 04:00 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
