Adding cruse control is a possible???
Old Jan 18, 2012 | 05:51 PM
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
I have an '87 Sports Coupe and today while driving home had a thought of adding cruse to my Camaro. Has any one ever done, if so how and could you even buy a complete kit to do this? Any advice would be great thanks.
Old Jan 18, 2012 | 06:41 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Adding cruse control is a possible???
Your best bet is to hit up a junk yard and pull it all from a doner car..
Old Jan 18, 2012 | 06:44 PM
jpearcy1's Avatar
Car: '87 Iroc
Transmission: 4L60e
Do you know how hard this would be or is it a waste of time??
Old Jan 20, 2012 | 06:23 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
not thta bad you need the servo
the entire harness and the vacuum hose form pedal switch to the servo
the pedal switch, the one with the vacuum hose port on it
the stalk lever switch from a column any gm late 80s to early 90s one from an f body or s10 or most FWD buicks and oldsmobiles are all same
some wires plug into fuse panel face
the rest plug into the servo and to the stalk lever switch and to the brake pedal interrupt switch
its pretty straightforward the hardest part is installing the lever switch stalk into the column
its tricky feeding the two wires for it down the column
maybe run a flexible stiff wire down the column and attach wires to that and pull tjem through with it like and electricians fishtape trick
if you need a stalk switch lemme know i have several good ones for your year style around
they can be hard to find good used and are pricey new usually
but they are common style in many gm vehicles, its the lever stalk for the wipers and bright headlights also
Old Jan 21, 2012 | 09:49 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
My guess is, your car already has the wiring. I'm pretty sure it was a standard option on all of these cars. The servo you can buy from AZ or Orielly's or wherever for about $80.00ish if you cant find one in the junk yard.
Old Jan 21, 2012 | 10:21 AM
TTOP350's Avatar
Around here there are many junk yards and 90% of these cars have all the cruise control stuff still in them!
wire/vac harness to and from the servo thats needed
brake switch for the cruise vac harness.
a vac ball under the batt tray on dr side of the car
the cable from the Carb,tbi/tpi to the servo
Im not sure if the dash will have the wiring but it may.
steering column lever and wiring.
Im sure there may be a few little things but thats a start.
Its a worth while swap 4 sure.
Old Jan 21, 2012 | 10:49 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I use my cruise all the time, whether 45, 55, 75 on the freeway. Anywhere the speedlimit is constant for a while, I'll usually set it. Mostly to avoid tickets because of "Speedo creep"...stupid phenomenon that seems to happen anytime a good song pops on the radio!
Old Jan 21, 2012 | 12:14 PM
jpearcy1's Avatar
Car: '87 Iroc
Transmission: 4L60e
I want it cuz I drive 30+ miles for college and crusie would be great! Im gonna do some Google and tech board searching and figure my parts list and amount of work needed.
Old Jan 21, 2012 | 02:01 PM
TTOP350's Avatar
look at your car up under the dash and hood. junkyard cars, and a GM service manual. That will help ya tons.
You most likely wont get it all on one trip.. happens to me all the time.
Old Jan 21, 2012 | 02:09 PM
jpearcy1's Avatar
Car: '87 Iroc
Transmission: 4L60e
If I rly need parts I can't find I can call my family that own the local junkyard.
Old Jan 22, 2012 | 03:25 AM
matthewehall's Avatar
would cruise control still work if you spapped an lt1 in it?
Old Jan 22, 2012 | 09:02 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Cruise is a completely independent system as long as you have the same induction (carb-carb, EFI-EFI) and has nothign to do with the motor. If you swap EFI-Carb or vice versa, you may need some adapters or get a unit out of a suitable car that youre swapping the motor from.
wigmobile
Feb 26, 2025 02:56 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
gta892000
Aug 11, 2019 11:16 AM
PurelyPMD
May 5, 2016 04:57 PM
dbrochard
Sep 7, 2015 09:41 AM
