Cleaning up my engine bay. What to do?
Old Feb 6, 2012 | 05:21 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
I would really like to clean up my engine bay and get some of these hoses out or anything that is not needed. I'd rather not have it looking like someone dumped a bucket of black snakes all over the engine
Old Feb 6, 2012 | 05:46 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: Cleaning up my engine bay. What to do?
Well, every single one of those hoses and wires is there for a reason. If you aren't required to keep all the original emissions equipment, you can do an AIR delete - remove the pump and all associated lines. An A/C delete will go a long way toward cleaning up the engine bay. You might be able to reroute some of those wires and vacuum lines, but I wouldn't recommend removing them.
About the only way you'll get a really, really clean engine bay is by building your car specifically for it, making it pretty much only good for shows and racing: drop in an older engine with no sensors and no EGR, get a simpler carb, delete windshield washer bottle and pump, delete charcoal canister. Some of this stuff might make your car not legal for street use.
Old Feb 7, 2012 | 08:15 PM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
here's where you'll be with a/c delete, smog delete, and headers. I'm still lookin to reroute the heater hoses and all the wiring associated with the a/c and smog pump, i also wana move my altenator to the passenger side so i can get rid of the mount for the compressor and air pump
Old Feb 7, 2012 | 08:16 PM
bigreed91's Avatar
Car: 1990 camaro rs
oh and here's the a/c delete box, helps clean it up some to
Old Feb 7, 2012 | 11:45 PM
Gsoleski's Avatar
Car: 1984 Z28
Thanks for the pic it looks a lot better than mine. Ill probably give those a shot
Old Jun 26, 2012 | 01:19 PM
Angrybird14's Avatar
Car: 1986 Trans Am
Engine: 305TPI
i got a question .. you know how wen u take the ac out n it has that filter in it what did u do to that metal rod connected to it in other words what is the metal rod sticking out from the bottom of that filter because i just broke mine off.n i wanna know wat it was for and if its important
Old Jun 26, 2012 | 05:52 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
It's your orifice tube, and ya, it's quite critical if you want your A/C to work. They are very inexpensive however, and should be replaced when you open the system.
Old Jun 26, 2012 | 06:00 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
First off you should start by removing that 5.0 H.O air cleaner and selling it to me.
Old Jun 26, 2012 | 06:21 PM
If you mean by that, "what can I hack off of it", one word:
DON'T!!!
Organize all your hoses and wires properly, laid down in the correct order on the engine with the ones that belong at the bottom of the heap on the bottom, instead of them all just being strewn everywhere like a 3rd grader installed them and everything all poofed up into a bird's nest like a female country music singer's hairdo. Use the correct size hose and make them the correct length. Replace some of the rubber replacements with the thin plastic originals and bundle ones that travel together, together.
And did I mention, DON'T HACK ON YOUR CAR!!! No sense in turning an otherwise potentially nice car into yerbasic hilljack turd by "improving" it that way.
Old Jun 27, 2012 | 12:16 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Too late sofa, he's already had 5 months with the snips
Infested
May 22, 2018 11:56 PM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
