Manifolds glowing red
Old Feb 6, 2012 | 05:53 PM
white04's Avatar
I have a 91 camaro rs that I just put a 350 in. I drove it up the road about two miles just driving normal and got home looked under the hood and my manifolds are glowing red. Anybody know what the cause of this could be? Thanks
Old Feb 6, 2012 | 05:58 PM
Gecz28's Avatar
Car: 88 iroc vert
Re: Manifolds glowing red
not sure, i know some turbo'd engines do that. maybe a clogged exhaust?? id be worried about a possible warped head.
Old Feb 6, 2012 | 07:19 PM
3318RS's Avatar
Car: 1990 RS
Transmission: Built-700R4
Your cat is clogged! My
Old Feb 6, 2012 | 07:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Could also be running very lean. Exhaust temp at WOT shouldn't get above 1300*. Glowing manifolds is a lot hotter than that.
Old Feb 6, 2012 | 09:30 PM
white04's Avatar
Thanks for all the help. Sharp lookin car ya got there 3318rs
Old Feb 6, 2012 | 09:49 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
If your exhaust system isn't clogged, then you have a very late spark, or a late burning fuel.
Retarded timing will do this, and running race gas in a street engine will do this. Running too much of a fuel additive or running E85 will also do this.
Clogged exhaust should cause a power loss and you should hear a wheezing sound or rattle in the exhaust.
The other conditions would also cause a noticeable power loss.
Old Feb 6, 2012 | 11:42 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Details on the 350? Injected, carbed, did you re-use parts from a 305? I'd suspect air/fuel ratio if this didn't occur with the old engine, assuming it's the same exhaust and you didn't drain/replace the fuel in the tank.
Old Feb 7, 2012 | 07:35 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
check timing and fuel
Old Feb 8, 2012 | 08:17 PM
3318RS's Avatar
Car: 1990 RS
Why thank you!
A lot of good suggestions here, let us know what it was.
gta892000
Aug 11, 2019 11:16 AM
86CamaroDan
Sep 29, 2015 10:08 PM
TheExaminer
Sep 28, 2015 02:28 PM
MORREALE5
Sep 13, 2015 09:01 PM
andy74
Sep 3, 2015 08:41 AM
