Need help with fuel leak
Hey guys,
I have a fuel leak coming from right behind the throttle on the top of the engine. It has a vacuum hose and fuel hose going into it. The gas nipple is busted and leaking.
My car is at shop right now and the guy is saying it is going to cost $650 to fix. This looks like something you literally plug in and wipe your hands.
Does anyone know the name of the part? It could help me save a good amount of money.
Here is picture:
Thank you for the help
Here is picture:
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Re: Need help with fuel leak
gas going through there??? that doestnt sound like its supposed to happen? i thout it was just vapors that are suppoesed to go through there just like mine, imne is a v6 3.1 from 1991 camaro.
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
ok i think i got it. look at google and look at MAP sensor connector. that should be what is troubling you.
hold on actually it is a vaccum hose, not the map sensor if im right. let me check on some more.
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Here is what i found. what year is ur camaro to find something more specific
DO NOT LET THEM FIX IT!! that is wayyyy to much. go to a junk yard and take that peice of a camaro and install on yours. 20 dollar fix instead of 650.
