HELP! Won't start, changed Spark plug wires, cap & rotor!
Old May 17, 2012 | 07:25 PM
PUNISH3R's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: V8 5.0 305 TBI
Transmission: 700R4 with B&M MegaShifter
Axle/Gears: Gear Ratio: 2.73 Ring Gear: 7 5/8
I thought I'd get a jump on this weekend's project. So I put in all MSD Street Fire Wires, Cap and Rotor and she won't start! I did each wire one by one. Plan to do plugs and Street Fire Ignition this weekend. She sounds like she wants too start but won't turn over! What did I screw up????!!!!!
Old May 17, 2012 | 07:41 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: HELP! Won't start, changed Spark plug wires, cap & rotor!
double check your firing order, two plugs to your ignition module on the distributor and the plugs on your coil.
Old May 17, 2012 | 08:54 PM
PUNISH3R's Avatar
It worked fine, then I pushed down on them on the Distibuter cap and it stopped starting.
Old May 17, 2012 | 09:04 PM
juanillox8's Avatar
Car: TOO MANY
Have you checked if you have spark at all??
Old May 17, 2012 | 10:01 PM
PUNISH3R's Avatar
The MSD Street Fire plug wires need to go in a certain way. 2 of them were the wrong way so I flippped them around. I double and triple checked all connections. And it still won't start. Could I have put my rotor on wrong? It's so easy, I yanked the old one off and slapped the new one on. I also did each wire, 1 by 1. Can't figure it out.
Old May 17, 2012 | 10:04 PM
juanillox8's Avatar
Car: TOO MANY
where in socal are you at?
Old May 17, 2012 | 10:48 PM
PUNISH3R's Avatar
I screwed something up d*mm it. And I just lost sunlight. Looks like 6am I'll try again.
Juanillox8 - I'm in SD.
Old May 17, 2012 | 10:53 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Are you getting any spark at all? To any cyl?
Old May 17, 2012 | 10:54 PM
juanillox8's Avatar
Car: TOO MANY
sorry to hear that...are the rotor and cap matching brand? sometimes the rotor doesn't touch the cap's "coil tab" long shot but that might be it... sorry but i need to ask again...have you re check your firing order?
Old May 18, 2012 | 12:44 AM
PUNISH3R's Avatar
The wire, cap, rotor, and coil are all MSD STREET FIRE. All brand new. Alright, re-wired all plugs again 1 by 1. Double checked firing order, its good. Took out new coil and put new coil back in, double checked those 3 connections, they are good. Only thing I didn't do was re-check the cap and rotor. I'm working in the dark so I have to hit it at sunrise. FACH!
Old May 18, 2012 | 01:34 AM
PUNISH3R's Avatar
Did I put the cap on wrong? It should only snap in 1 way right?
Old May 18, 2012 | 01:36 AM
PUNISH3R's Avatar
Not the cap, I ment the rotor. Could I have put it on wrong?
Old May 18, 2012 | 09:39 AM
juanillox8's Avatar
Car: TOO MANY
doubt it..it olny goes in one way...im gonna pm u check ur messages
Old May 18, 2012 | 09:47 AM
PUNISH3R's Avatar
Great, thanks.
Old May 18, 2012 | 01:30 PM
PUNISH3R's Avatar
juanillox8 & I figured it out this morning. Distributor cap wasn't seated correctly and got chewed the &%$# up along with the rotor when it spun! DARN IT! Just walked to the Auto parts store and got another one. Lets see if it works. Someone learned about caps and rotors today
Attached Thumbnails HELP! Won't start, changed Spark plug wires, cap & rotor!-street-fire-cap-chewed   HELP! Won't start, changed Spark plug wires, cap & rotor!-street-fire-rotor-chewed
Old May 18, 2012 | 01:44 PM
juanillox8's Avatar
Car: TOO MANY
figured it out urself buddy ....line up the cap with the groves on the ignition mudule first and them tighten it... thats how you know its sited right
Old May 18, 2012 | 02:36 PM
PUNISH3R's Avatar
Whatever, Dude. You helped me, probably at the office instead of doing work! Anything is better than work. Put the new one in, took 5 minutes. She fired right up.
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Brcharrelson
Aug 26, 2015 07:47 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
