454 swap shifting issues??
Old May 21, 2012 | 05:19 PM
charger69black's Avatar
Hello I am in the need of some advice and help i have a 1991 camaro rs that i have completed the 454 and carb swap. i used the factory transmission for now. i noticed that the car shifts way late and hard like at 3k and so forth also it does not downshift when i punch it. i have installed the tps sensor for the holley carb and also the map sensor for the factory ecm this helps a little bit when warmed up but is still get no tcc lockup as hwy cruise and no downshift does anybody have ant ideas thanks
Old May 21, 2012 | 06:25 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: 454 swap shifting issues??
What type of transmission do you have.
Old May 21, 2012 | 10:36 PM
It a 700r4 electronic. I was thinking that it is because my ecm is not seeing engine rpm because I have installed am hei distributor instead of the computer controlled one so I need to figure out how to give my ecm crank signal
Old May 22, 2012 | 07:02 AM
Edwardgp's Avatar
Engine: 454-350
Sounds like you figured it out, nice car you have.
Old May 22, 2012 | 10:54 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
The 700R4 is not "electronic", and it doesn't know or care what RPM the engine is running at. For that, you'd need a 4L60e.
To me, it sounds like your TV cable is not hooked up or functioning correctly. That, combined with the governor are what manage your shifting, both when it shifts and firmness. Since you put in a carb'ed BB, how did you hook up the TV cable?
Old May 22, 2012 | 01:57 PM
ok i got the old factory computer controled distributor and still same thing no down shifts and no tcc lockup. my cel is off now haha but still having issues.
tom 400 i have the tv cable connected with the holley adjustible bracket i have tried adjusting it but see no change when i removed my trans pan i see a few elecrical solenoids so i know that it has to be electrically controled or partialy controlled
Old May 22, 2012 | 02:03 PM
I have all the sensors connected iac, tps, cts, map, oil pressure and stock ccdis. I would like to get down to the bottom of this issue any help is much appreciated. I know i can get a built 700r4 that is not electric and will down the road but for now i want to have a good cruiser and i need lockup and a decent shifting rpm
Old May 22, 2012 | 02:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The computer has nothing at all to do with the shifting of a 700R4.
Are you trying to keep the computer just to control the TCC? Don't even bother, just pick a non-computer way of controlling it and wire it up.
Old May 22, 2012 | 03:15 PM
ok now i went out and adjusted tv cable and come to find it was to tight. now it seems to shift at 2k instead of 3k and now at 60mph i am at 1500 rpms wich i like thank you tom 400. now the question is do i go back to hei dis or stick with the computer controlled stock dis???
Old May 22, 2012 | 03:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Use the non-computer HEI, not the computer-controlled HEI.
Your computer is pretty well useless now, it's a lot to get rid of it than try to figure out how to keep it limping along for a few residual functions.
Old May 22, 2012 | 03:31 PM
yeah I am trying to keep the computer involved as much as possible i will probally buy that external speed sensor tcc kit anyway thanks man
xxxxzzzzz.jpg?t=1337718537
zzzxxssz.jpg?t=1337718574
Old May 22, 2012 | 06:42 PM
Engine: LT1, L400
Those are to control the lock up tq converter. The shifting is not electronically controlled in any way, shape or form. Governor and TV cable manage the shifting. And orfice size (whcih I assume hasn't changed -you haven't put in a shift kit, right?).
Old May 22, 2012 | 06:51 PM
Engine: LT1, L400
Somehow, I missed this post, and those below it. Glad to hear you are making progress. I agree that trying to keep the ECM 'alive' and functioning just for TCC is wasted effort. If you can manage it, a simple toggle switch would work fine. You don't want to forget and drive it for extended periods in OD w/the converter locked however.
Old May 24, 2012 | 05:16 PM
yeah i understand. I am still playing around with the shifting seems to get better the warmer it gets but when cold it still wont shift untill about 2500 but after driving it around alot it start to lower the shifting rpms f it ill just buy a monster 700r4 and worry about it all later.
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
mizz0313
Aug 12, 2015 06:45 AM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
