90 camaro rs 305 tbi
Old Oct 23, 2012 | 06:19 PM
starnes28's Avatar
Car: 1990 Chevy Camaro RS
Engine: 305 TBI
I got a 1990 camaro rs with 305 tbi and its started to stall out right after it starts but only does it when its warmed up and it only does it once everytime I start it when its warm. I have no idea why. Can anyone help me
Old Oct 23, 2012 | 06:21 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: 90 camaro rs 305 tbi
check for codes first.
Old Oct 23, 2012 | 06:24 PM
starnes28's Avatar
Engine: 305 TBI
Even if the check engine light isn't on
Old Oct 23, 2012 | 08:22 PM
bungy74's Avatar
Car: 1992 Camaro Z28
Engine: 5.0 TPI
Transmission: auto
faulty ignition module will do that and not give any codes
Old Oct 23, 2012 | 08:29 PM
ninetyone's Avatar
Axle/Gears: 3:42
yep ,check anyway and bungy74 is right too, Also bad fuel injectors will not throw a code either.
Old Oct 23, 2012 | 08:35 PM
bungy74's Avatar
Engine: 5.0 TPI
Transmission: auto
you may want to check fuel pressure also before replacing any parts, many times people overlook a weak pump
Old Oct 24, 2012 | 12:13 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
I've heard of this!, i cant remember exactly what its called but what was described was...when you turn your car off the fuel in the lines near the motor absorb the heat from the engine (ahh its called heat soak) anyways when this happens i guess it messes with the fuel somehow not allowing it to start. I don't remember why, look up heat soak, if it only doesn't start when its hot and will then start once it cools i'd guess this is it.
Old Oct 24, 2012 | 12:39 AM
ninetyone's Avatar
Axle/Gears: 3:42
seriously doubt its heat soak.
Old Nov 3, 2012 | 05:24 AM
Vince Rolon's Avatar
Car: 1990 Camaro Rs
Engine: 305 TBI
I just bought one and had the same problem. The previous owner told me it was the IAC or idle air control sensor. Then i checked the EGR and replaced lines...turns out it was the 3 dollar PCV valve my dumbass over looked.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
